20 Most Recent
Fisher and Paykel (IWL12) Questions & Answers
Error code 136 Fisher & Pykel washing macine
Hi just read your posting.Now Error code 136 means you have a motor stall fault.This means the motor controller cannot start the motor turning.Has your machine been noisy on spin?The things that cause this fault are,seized or faulty bearings, wiring to the motor faulty,faulty motor,faulty rotor position sensor, or faulty motor controller.Do you have or can borrow an electrical test meter ?If the answer is yes I can guide you throe the testing of the components to track this fault done.Please reply with additional information about the spin cycle and if you can get a meter and I will help you further.
Washing machine won't turn on
For the F&P machine.
Check the circuit board fuse. I had my machine do exactly the same thing. Just wouldn't power up at all, no lights, nothing.
The fuse is on the circuit board a small round red unit, with T1.6A250V written on the top.
Remove the 2 screws securing the control panel. Inside there is a grey plastic box. This houses your circuit board. You will need to have a multi meter and a soldering iron to replace this component.
Smart drive 085
It won't spin until all the water is drained out. The drain pump may be blocked or faulty. Fix the drain pump fault first then deal with the filling issue. They will not be related.
Fisher & Paykel smart drive - all the lights come on!
It has put itself into the display mode (used in shop displays) Try turning power off and unplug from the wall outlet for a couple of minutes. Plug back in and see if it has come back to normal. If not then either the display board or the main board will need to be replaced. Get a service tech out to check which one is faulty.
Machine will not power up. No lights at all can you help please?
have you checked the fuse in the plug? try replacing it, or plugging into another wall socket, also check the actual socket it is plugged into works by plugging something else into it. If none of the above works then looks like you have a problem... first check would be to turn off the power at the wall and check the whole power cable from start to end looking for any splits or possible kinks or areas where a mouse or rat could have chewed it perhaps...
Model IWL 12 error code
CODE 12: Flood protection error.
If the water valves are on contiuousy, check that the valves
turn off mechanicaly (remove power from smart drive.
Secondary source: check the pump for blockage and drain hose
for correct height and kinking
