20 Most Recent Fisher and Paykel Fisher Paykel Intuitive Eco Washer IWL15 Questions & Answers
My Fisher and Paykel washer is leaking water from bottom back right side in the rinse cycle. Any thoughts?
Question edited to correct name of maker, (Fisher PayPal :>) Question moved to one of their categories. No clue to whether a top loader or a front loader, which is why we ask for full 'make model (what it is)'. If it is only in the rinse cycle, and if it is a front loader it is likely to be spray of a crack in the box that is the detergent drawer and fabric softener mixer. The only way to find out is to remove the top after a wash and look for where the water came from. Some other ideas here https://www.google.com/search?q=Fisher+and+Paykel+washer+is+leaking+water+from+bottom+back+right+side ..
3/29/2022 1:33:21 AM • Fisher and... • Answered on Mar 29, 2022
3answers
Intuitive eco washing Machine says power cut and lights continually flash
Here is how I fixed mine using the knowledge of years of fixing things.
I grabbed the machine from the top with both hands and shook it off the floor very hard with a good thump X 2
I went to university for longtime to know this is how to fix it;
The circuit boards and sensors are not bad. It just after years of bumpy spin cycles there is a loose connection. This will shake the troublesome connection into a new position where it makes better contact.
It's temporary.
One day you'll have to open it and check all the connections are tight and clean.
8/14/2021 6:43:05 AM • Fisher and... • Answered on Aug 14, 2021
2answers
Fisher & paykel mw511 pride
Check the pipes actually work first. Is there a hidden drain filter that is partially blocked? Dissasemble the pump and check it works and the blades inside are clean.
10/20/2020 6:52:13 AM • Fisher and... • Answered on Oct 20, 2020
2answers
Code error 131.
Hi just read your posting.Error Code 131 is called REPETITIVE ROTOR POSITION SENSOR ERROR..The 3 reasons this fault is appearing is 1--the wiring to the rotor sensor is faulty.--2--the rotor sensor is faulty.--3-- the motor controller is faulty.If you have or can borrow an electrical test meter I can help you test the wiring but to test the rotor sensor you need a tester called RPS tester.Please reply on how you would like to proceed an I will help you as much as I can.
4/21/2020 3:16:25 AM • Fisher and... • Answered on Apr 21, 2020
3answers
FP fault 43
code 43 is an out of balance switch problem.Once replaced, would fix the issue.
One trick that might work ;-
I unscrewed top cover, then unscrewed and lifted up the grey computer cover. The balance switch is underneath on the right with a yellow and white wire coming off.
I removed switch from clip and then removed the wires/clips from contacts. There was definitely corrosion on the contacts. I soaked switch overnight in vinegar. Then rinsed with water. Then dried switch out for day.
Put it all back together and am now on second load of washing.
Thanks.
4/15/2020 3:35:12 AM • Fisher and... • Answered on Apr 15, 2020
2answers
Needs Service code 136
136. (10001000) Motor Stall The Motor Control Module has been unable to start the motor. Possible causes of this fault are: Faulty motor harness, faulty or jammed motor, seized bearings or seals, faulty Motor Control Module, faulty Rotor Position Sensor or harness. Primary Source: Wiring. Action: Measure/check the motor harness, connectors and motor for discontinuity. This can be done by taking a resistance measurement between phases of the motor harness at the Motor Control Module end. Nominal resistance should be around 32Ohms. Secondary Source: Motor. Action: 1) Check free rotation of the agitator and basket by rotating by hand. Bearings and seals may be seized. 2) Check the Rotor Position Sensor and associated harness for water, mechanical damage or corrosion. Tertiary Source: Motor Control Module. Action: If the primary and secondary checks pass inspection, then replace the Motor Control Module.
5/5/2019 9:36:42 AM • Fisher and... • Answered on May 05, 2019
2answers
2answers
2answers
Bearings
I can talk you througt this in live chat, but you'd need to get a F&P Bearing replacement toolkit and seals and bearings and a new agitator shaft. cheers
2/25/2019 6:39:05 AM • Fisher and... • Answered on Feb 25, 2019
2answers
Error code 43
Hi just read your posting.Error code 43 is called OUT OF BALANCE SWITCH ERROR.This means either your switch is faulty or your your control module is faulty.95 % of the time it is your switch which is located under the control module which is under the top panel.If you want I can guide you step by step in the replacement of this switch.Please reply on how you would like to proceed and I will help you as much as I can.Looking forward to your reply.
12/12/2018 3:52:20 AM • Fisher and... • Answered on Dec 12, 2018
25answers
Error code 37
I also got Error Code 37 at the end of a wash with the machine full of suds. I used the other information listed under this problem to establish that the pump was blocked, (no amount of hand-turning loosened the fan). After unplugging the machine from the wall, I removed the pump easily by unplugging the power and earth from the pump, pressed in a clip on the side of the pump to allow the whole pump to rotate and then pull out, (a bayonet type fitting). From where the pump came out from was a small piece of cloth and other gunk! I refitted the pump and reconnected the power and earth. The machine is now working happily again.
12/2/2018 11:08:03 PM • Fisher and... • Answered on Dec 02, 2018
2answers
Fisher paykel error code 37
check drain pump is not blocked or faulty
11/29/2018 8:52:18 AM • Fisher and... • Answered on Nov 29, 2018
Hi I have a fisher
if it keeps filling until it floods the it has afaulty transducing which is locatedin the mainboard which will have to be replace
4/21/2018 2:43:52 AM • Fisher and... • Answered on Apr 21, 2018
Fisher & paykel bar fridge - product 12019,
repace the thermostat
4/21/2018 2:33:30 AM • Fisher and... • Answered on Apr 21, 2018
My washing machine IW812 has fault code 37.Could
pump block error remove pump check foranything blocking or jamming it it that fails replace pump
4/21/2018 2:29:20 AM • Fisher and... • Answered on Apr 21, 2018
Fault code 38 in intuitive eco washer
this code indicates a faulty main board
4/21/2018 2:00:58 AM • Fisher and... • Answered on Apr 21, 2018
Fisher and paykel agitator flap broken can this be replaced?
top loader yes remove cap off top of agitator there is a plastic wing nut at the bottom undo anticlockwise and agitator canbe removed and replacement
4/21/2018 1:39:49 AM • Fisher and... • Answered on Apr 21, 2018
Fisher Pyle not getting any water
faulty cold water solenoid or sensor
4/21/2018 1:20:45 AM • Fisher and... • Answered on Apr 21, 2018
What is error code 66 on a fisher & paykel IW12 top load washer
this is a faulty transducer which is located on the main board unfortunatley you will need to replace the whole thing
4/21/2018 1:19:54 AM • Fisher and... • Answered on Apr 21, 2018
Why does a fisher & paykel washing machine bowl drop low
its suppsed to as long as it even
4/21/2018 12:58:31 AM • Fisher and... • Answered on Apr 21, 2018
Washing Machines Logo
558 questions posted
Top Fisher and Paykel Washing Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Fisher and Paykel Washing Machines
Most Popular Question
code error 131
  • Washing Machines
