20 Most Recent
Asko W6461SS Front Load Washer Questions & Answers
F4 signal. What does this mean?
Welcome to FixYa.
I can tell you on the Asko machines the "F4" indicates an error related to the thermistor.
Whether the thermistor is actually at fault is another matter. It may be a faulty wire connection, the thermistor has become dislodged from the bracket mounting it to the tub or yes indeed the thermistor may be at fault.
Here`s what to look for and what it does...
THERMISTOR
Part no. : 80 616 63
Resistance: 40-60K ohms
Room temperature: 68°-86° F (20-30° C)
The thermistor ( for temperature measurement ) is
located between the motor cradle and the holder.
The thermistor measures and controls the water temperature via a heating element. In the event of errors the heater is switched off and F4 displays if the thermistor short-circuits or is disconnected from the program control board or programmer.
**unplug the unit from the dryer or wall whichever applies to your situation...safety first**
If you are capable, remove the rear panel and top panel to ohm out the thermistor to verify if it is within` the values I provided...or perhaps it has dislodged from it`s position as I alluded to.
In the event you need a thermistor and you feel you can replace it yourself I`ll show you how...I do recommend calling in an authorized Asko service provider.
CHANGING THE THERMISTOR
1. Remove the top cover as mentioned
2. Remove the rear panel as mentioned
3. Remove the thermistor by pulling it out to the left.
4. Remove the thermistor header connector from the program control board.
5. Install the new thermistor by threading it through the hole between the cradle and holder.
6. Connect the thermistor to the program control board.
7. Replace the rear panel.
8. Replace the top cover. (Don't forget the two
star washers for the outer screws.)
Hope this helps move you forward or at least gives you an idea of what needs to be looked at.
Let me know if you require further assistance or this is not clear I can post pictures/illustrations. Thanks for choosing FixYa today.
Good luck.
Regards,
Macmarkus :)
Asko W6984 Front Loading Washer Won't Agitate or Spin
No wash agitation or spin? try these:
WATER PRESSURE SWITCH: This switch keeps your washer from overflowing. It is responsible for shutting off the power to the fill valve and redirects the power to the timer to start the washing machine running once the correct water level has been reached. Meter check ur water pressure switch?
You can test it with a meter and with a manual test? ( first locate it in the panel, it has a plastic clear tube hose going into it, remove that tube from its connection, now put another small tube or hose into the slot where it was and have the machine set to wash cycle with water in it. Blow into the other end of the tube.
If the machine starts to wash. the pressure switch is more than likely good
( No wash starts - then THE DIAPHRAGM IS BAD AND SWITCH HAS TO BE REPLACED) another test u can do is Remove the hose and submerge in water. Seal one end and blow air into the other end and look for bubbles. Check for an obstruction in the hose as well.
Or take the original hose tube and plug one end and blow into it AT the other end, it should be hard and have pressure, if it is easy to blow and u dont feel any pressure and it feels like the air is going out ?
Sometimes they get busted open or a pin hole and release air causing the water switch diaphragm to not open.
Another test u can make with a multi meter is by testing the prongs individually.
# 15,16,17 (don't worry to much bout the numbers IF U GET THEM WRONG) place ur meter prongs on both out side prongs or connectors of the switch.
(where the wire plugs into) take note of weather it shows OHMS or infinity ( open or close circuit) ? Now place the meter on the left outside and the middle prong, take note agin what it shows. Now place meter prong on the right outside and the middle prong. Agin take note what reading u get. ( you should actually get a reading of infinity in 1 and a reading of continuity or ohms in the other 2? Now the tricky part. Agin place a small tube or hose into the switch and blow into it, using the meter do the same test agin on all prongs. But now keep the pressure on the switch when u blow into it, in other words use ur tongue on one end of tube to not allow air to escape. When u test it agin now one of the prongs that once read infinity should now show continuity or ohms, and 1 of the other prongs that read ohms should now read infinity or open.
Motor Coupling If the washer won't spin or agitate the motor coupling might have failed. The motor coupling connects the motor to the washer transmission. It is designed to fail if the washer is overloaded in order to protect both the motor and
Drive Belt If the washer won't spin or agitate, check the drive belt. If the belt is broken or if it isn't tight on the pulleys the washer won't spin or agitate properly.
mode shifter and or Drive Motor If the washer won't spin or agitate the drive motor might be defective. This is not common. Check all of the other related parts to this symptom before replacing the motor. If the motor is visibly burned out or physically damaged, replace it.
Stator Assembly If the washer won't spin or agitate the stator assembly might be burned out. The stator is essentially one half of a motor, it interacts with the tub by creating a strong electro-magnet. If the stator burns out the washer won't spin or agitate. Check the stator for continuity. This part is often misdiagnosed.
Transmission or clutch assembly not engaging due to going out or slipping.
Door or Lid Latch Assembly If the washer won't spin or agitate the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer won't spin or agitate the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Motor Control Board If the washer won't spin or agitate the motor control board might be defective. The motor control board provides power to the motor as well as direction and force. If the motor control board is defective the washer may not work at all or function properly.
CHECK THE CAM DOGS INSIDE THE AGITATOR, AS THEY WILL HINDER THE AGITATION PROCESS. However in G.E models the cam dogs are replaced with what is called an agitator coupler. (located at bottom of tub)
Remember to check the agitator spline as well for worn broken teeth.
ASKO w6884 Eco vibrate violently when spins
It is so common that the washing machine can make terrible noise in many ways and is a common fault. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that machine is vibrating when it is running then the motor /drum suspension has to be inspected. Since these fittings are located on the underside of the machine it is important that you look for the noise with a good inspection lamp. Manually turn the motor and drum and listen for the noise, if so the motor bearings, the drum agitator shaft and fittings must be checked. Also the suspensions which include the shock absorbers and springs, the body clamps must be checked to be in correct alignment and not changed in position. Tightening of the mounting is also very important. Finally in most cases a drop of OIL or smear of grease on the moving parts cane solve most issues.
Check this link :
http://www.espares.co.uk/advice/washing-machines/a/7/1210/wobbly-washing-machine-or-tumble-dryer.html
Asko front loader can I take off hose to use tap
If your dishwasher uses a quick connect hose to the faucet, you can disconnect it while the dishwasher is running ONLY IF the water is shut off and pressure release button is pushed in to release water pressure inside hose. If the dishwasher is calling for water, it will accommodate for a short loss of time. Remember to turn water back on when hoses are reconnected.
Our ASKO washing machine won't work.
Edited text for clarity. Moved Category form Drills to Asko washing machineThat is a power leakage to earth. It is either a fault with the motor or a damaged wire.
Asko 20004 washes but won't spin
This is a motor fault issue.
As I don't know your ability in repairing or what tools you possess.
Simple solution: other then have a repairman do this, the motor has something causing a fault. The vast majority of times in an asko because the motors spin at high speeds then most others is that the brushes wear out. So they most likely need a repair. Turn off machine, remove motor replace brushes.
There other possibilities such as electrical problems but I reckon brushes are the problem, could cost $60 for the pair and takes maybe an hour or two depending the skill of the person attempting.
This is not complex just dirty
I do not endorse repairing any appliance without proper experience in repairing appliances. This is only informative.
