20 Most Recent
Hunter 33251 2.5 Gallon Humidifier Questions & Answers
Hunter humidifier 33251 - is
According to the Owners Manual, there's no way remove the top covering the fan. Just clean with a damp cloth and then wipe it draw. However, before wiping it with a damp cloth, you may want to try blowing out the sections of the grill with some canned compressed air with a straw nozzle (like you clean your computer with). Or use a vacuum cleaner with a hose and brush attachment. After doing that, wipe with a damp cloth and then a dry cloth.
If you need a copy of your Owners Manual, you can download and print it from the following website:
http://www.hunter-humidifiers.com/manuals/33250.pdf
NOISY FAN ON HUMIDIFIER HUNTER 34356
Try using WD-40 or sewing machine oil on the bit that the blades are independent from the motor usually just a small opening that you can try to spray some lubricant in there which will reduce friction and noise by lubing up the bearing and decreasing wear if that helps you will then know what the underlying issues are and if you need further action
9/24/2017 3:12:07 PM •
Hunter...
Answered
on Sep 24, 2017
Carrier humidifier 49fh024120
A pair of wires should go to some power source...and pass through the humidisat (not thermostat). The clicking sound you will get whether there is power there or not. Try and trace those wires to a power source off the furnace.off a little metal unit called a transformer. new home. it should work unless they left the wires off for the owners to hook up...or for some electrician to do the final hook up. It its a new home, don't be afraid to call the builders. They are expecting you.
10/17/2013 5:46:54 AM •
Hunter...
Answered
on Oct 17, 2013
