20 Most Recent
Akai PDP4206EM Television Questions & Answers
Color went in and out, no i only get fair black
I'm assuming here that this tv is being used for analogue reception because on digital you either get a perfect picture or when the signal is weak enough, nothing at all (common when trying to use rabbits ears or in poor reception areas). Assuming analogue then, when the signal is weak (grainy or snowy picture) the colour (called chroma) is automatically turned off because grainy colour is unwatchable. This is normal. Solution, a better aerial to provide a stronger signal.
AKAI PDP4206EM with sound but no picture. I have
Hi
Thanks
for using FixYa. A plasma TV is a very hard working device. It is
working harder than any TV that has been built before, and as a result it
produces a lot of heat. 75% of technical problems in plasma TV's are caused by
overheating problems. The problem you may have is dead driver (part
of a screen) or poor connection between plasma glass and ribbon wire
connector. X, Y sustain, buffer boards controls
picture, fires the gas, and many others functions. When either of these boards goes
bad common problems include negative image, no image, vertical or horizontal
stripes on picture, turns on and than turns off, and many more. You’ll need to
open the back off the TV and check for any swollen/bulged/leaky capacitors on these
boards and replace whichever has gone bad. All this is only recommended if you
have electrical expertise & know how to solder/re-solder components as these
units contain high voltages even when switched off.
Please do
accept the solution if the issue is resolved or else revert for further
assistance.
Thanks
Rylee
I have an Akai PDP4273mi.
Go to this WEBSITE Encompass Parts Distrubtion Look up your Model # PDP4273m1 They list Main Board for $1,031.46 - core fee $253.00
making cost of board $778.46 Part# 771E421D02-02
When I turn on my tv all that comes on is three
Hi:
If these lines are at least 2 inches wide then the problem is the display driver boards or some call them the Buffers boards, if the lines are less then 2in in wide and are very thin lines then the PDP is bad (Screen).
Tv wont turn on
The green light flashing indicates an error code, plasma tv's cannot be repaired at home without the right equipment and service manual, the fault could be power supply, processor or virtually anything, what technicians look for is the frequency of the blinking and the time between sets of blinks, this normally gives the tech a code that enables them to go to the right area, the only thing anyone can tell you is that the processor is probably ok, you really need to get a quote or count the blinking and the timing eg: "blink blink short pause blink), and repost the fault, then we can possibly tell you where to look...Phil
Need Codes for Akai television using Stang F-2100 universal remote.
It is 2023, no one uses Universal Remotes these days!
https://www.fixya.com/support/r29872378-universal_remotes_no_facsimile_remote
Codes are to the television maker, they don't change depending on the make of remote used. But as I said, no one buys universals, you buy a copy remote made for the make model you have.
Akai TV universal remote control codes (3, 4 and 5 digit)
eliztech.com
https://www.eliztech.com > remotes > codelists > akai-t...
Universal remote codes for Akai TV sets - 3 digit, 4 digit and 5 digit codes. ... Mixed Akai TV codes from nine brands of universal remote controls.
3, 4, & 5 Digit Akai TV Remote Codes with Programming Guide
smarttvremoteapp.com
https://smarttvremoteapp.com > akai-tv-remote-codes
Akai TV Remote Codes for DirecTV ; 11385, 11692, 11935, 12232 ; 10765, 10812, 10030, 10098 ; 10672, 11676, 11689, 11690.
Universal Remote Codes for... ·
Akai TV Remote Codes for Dish
I have a pdp4298ed1 akai TV with a digital antenna screwed into the ant in. How do I scan for digital channel's?
To scan for digital channels on your Akai PDP4298ED1 TV, you can follow these steps:
- Press the "Menu" button on your TV remote.
- Use the arrow buttons to select the "Setup" menu and press "OK".
- Use the arrow buttons to select the "Installation" option and press "OK".
- Select "Automatic Search" or "Auto Scan" and press "OK". The TV will begin scanning for digital channels.
- Once the scan is complete, the TV should display a list of channels that it has found. You can then use the arrow buttons to select a channel and press "OK" to tune to it.
If the auto scan feature does not work, you may need to try a manual scan instead. To do this, follow the same steps as above but instead of selecting "Automatic Search", choose "Manual Search" and enter the frequency of the channel you want to tune to. You can find the frequency information for your local channels by doing a quick online search or checking with your local TV provider.
