20 Most Recent Fujifilm Finepix Ip-10 / Ip10 Digital Camera Photo Passport Picture Printer Questions & Answers
it doesnt need a driver. you plug in the usb cable, although there may be a difference when printer is ON before pc is started. https://www.fujifilm.com/products/digital_id_photo_printer/finepix_printer/#specifications
Fujifilm Finepix... | Answered on May 22, 2019
http://www.fujifilm.com/products/digital_id_photo_printer/finepix_printer/
Fujifilm Finepix... | Answered on Jan 19, 2015
Follow the "instructions" in the "manual"
Fuji Cameras | Answered on Sep 19, 2019
Check batteries and the terminals that connect to your batteries. Often the contacts get corroded because batteries have acid in them.
Fuji Cameras | Answered on Aug 13, 2019
Ebay or Fuji, possibly ?
Fuji Cameras | Answered on Jun 20, 2019
This query does not appear to relate to any model of camera - are you sure you have posted it in the correct forum ?
Fuji Cameras | Answered on Jun 07, 2019
Simply download it from Fuji website! If that is not possible, google it.
Fuji Cameras | Answered on Mar 22, 2019
It sounds like maybe one of the pins are broke, I wold try flashlight and magnifying glass to inspect it, If you find one of the mettle contacts on the card is broke it is probably ok to just pull it out firmly it will break the card contacts but I doubt it will harm you camera ~T?M~
Fuji Cameras | Answered on Feb 27, 2019
Is the display blank only after taking pictures, or blank all the time (i.e., can you see the menus)? If you can see the menus, try performing a Reset All (page 67 in the manual). The idea here is to set the contrast/backlighting to factory presets.
The manual can be found here.
If the display is blank all the time, try holding it near a bright light and look at it from different angles to see if you can see any image on the display (if the backlight isn't working, you may be still able to see items on the display). If that's the case, you may be able to navigate to the menus and perform a Reset All.
Otherwise, pull the batteries out and leave them out for a longer period of time - several days, if possible. This should also reset the camera.
Failing this, you will likley need to send it in for repair.
Fuji Cameras | Answered on Dec 25, 2018
look inside the battery port
Fuji Cameras | Answered on Nov 27, 2018
Fujifilm Finepix Ip-10 / Ip10 Digital Camera Photo Passport Picture Printer Logo
6 questions posted
Top Fuji Cameras Experts
Ekse
Steven Wander
Steven Wander
Azam Ali
Level 1 Expert
Are you a Fuji Camera Expert? Answer questions, earn points and help others
View Most Popular
Fuji Cameras
  • Fuji Cameras
Most Popular Question
fujifilm finepix printer ip 10 driver
  • Cameras
