All appliance manufacturers test 1 out of every 5-10 appliances as they come off the assembly line. If you got a new unit and it is wet inside, this is a good thing, this means that your unit was actually factory tested. Obviously, they aren't going to take the time to dry out every unit that is tested, they box them up and ship them out knowing that they are going to be in a customer's home very soon anyway.
1. rinse aid reservoir is empty
2. water is hard and the setting for water softener needs to be readjusted
3. there is no salt in the hard water reservoir
4. incoming hot water temperature is not adequate
Refer to user manual at this site if you do not have one.
Empty the dishwasher. Remove all dishes including pots, pans and silverware.
Pull the bottom rack out as far as possible. The filters are under the basket on the Maytag dishwashers. It may be convenient to lift the rack out. Typically, if you lift, the wheels leave the track.
Remove the "Coarse" filter. This filter is a small, round knob in the middle of the "Fine" filter. A round knob is around the "Coarse" filter. Hold on to the handle and lift straight up.
Knock the contents of the "Coarse" filter into the garbage can. Run the faucet to remove smaller particles. Wipe the dishwasher filter with the sink sponge if debris is stuck-on. Push back into the filter holder when complete.
Take out the "Fine" filter. Turn the round knob that is around the "Coarse" filter counter-clockwise. Once the knob is loose, pull up. The "Fine" filter will come out of the dishwasher.
Rinse the "Fine" filter with the hot water faucet. Scrub with the sink sponge to remove any stuck-on fragments. Replace the filter into the dishwasher. Push down and turn the knob clockwise to tighten.
Thanks for your question! I'm sorry that you haven't received an answer yet. The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when: 1. the question is unclear, incomplete, or poorly worded... 2. the question is mis-categorized - so the correct experts aren't viewing it... 3. the question requires an answer for something that cannot be explained online adequately... 4. specific training, tools, or equipment are required to avoid injury or death... 5. the Experts that are online simply don't have the resources to answer your question fully... Please feel free to re-work your question if you feel one of these may be the reason. Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well. Normal rates for FixYa are... $ 9.99 answer for one question. $12.99 Live Real-Time online chat or premium e-mail support. $29.99 Live Real Time phone support Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership. Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
I suspect something hard like a fragment of chicken bone or a citrus seed is at the inlet to the drain pump (my favorite was a plastic pull strip from a frozen juice concentrate can - that was LOUD). Many dishwashers have a chopper similar to that in a garbage disposal right before the pump inlet, but some things like bone won't go through it. It could be something light enough to float and only hits the pump when the water level drops. You may have to remove the pump cover in the bottom of the dishwasher to find it. This would be a good time to clean any garbage out of the lower spray arm and check the spray arm bushing for excess wear.
5Found This HelpfulGeorge Doyle/Stockbyte/Getty images
Dishwater residue is a fairly common occurrence, and several things can cause it. Even the newest dishwashers may leave residue, and it might have nothing to do with the actual dishwasher function itself. However, there are things you can do to prevent, limit or completely remove dishwasher residue during every washing cycle.
Modern phosphate-free detergents are the main culprits when it comes to detergent residue. After every wash, many leave a slight whitish residue behind. After several washings, the residue becomes caked on and leaves a noticeable white tint to your dishes. Some dishwasher detergent brands are better than others, and either minimize residue or do not leave any. Once residue is present, however, the only way to remove it is by hand scrubbing or scraping.
Hard-Water Residue
Hard-water residue comes from non-softened water from your hot water tank. Non-softened water leaves a white tint on dishes, but no amount of scrubbing will remove it. Only by wiping a small patch of the dish with vinegar or lemon juice will you be able to ascertain whether the white residue left is hard water or detergent. The slight acidic action of the vinegar or lemon juice removes hard-water stains, but they have no effect on detergent residue.
Greasy Residue
If the dishes feel greasy when they come out of the dishwasher freshly washed, you are dealing with a greasy residue. There are two main reasons for this: either the detergent is not an effective grease remover, or the hot water inside of the dishwasher, either from the hot water tank or the dishwasher's heating elements, is not hot enough. Boosting the hot water temperature on the water tank may solve the problem, and a second wash cycle may be needed for the dishes. A preventive measure of running the dishwasher empty with a full load of detergent also removes the residue inside of the dishwasher.
Streaking and Spotting Residue
If you have spotting or streaking on your dishes, that may be a sign you need a rinse agent. Many modern dishwashers recommend a rinse agent to prevent spotting or streaking, and without one, your dishes will never be crystal clear or streak-free. The next time you do a dishwasher load, add a rinse agent. If the dishes come out spot- and streak-free, the problem is solved.
i don't know. sounds like a fault in the program. consider unplugging machine for 10 mintes. plug it back in and run a short wash to see if the program has reset itself. if not OK, call for repair estimate then decide if you can live with it as is,-- have someone try to repairit -- or replace it with a new one which may offer extended warranty for $$.
google Maytag Quiet series 300 Handle and latch
there are several new handles about $30-35.
link to how to replace handle
copy and paste
https://www.youtube.com/watch?v=Tfw0F5XeWHY
google maytag dwu7400aax dimensions for your answer less than 3 seconds.
This is just a standard size dishwasher model. Dishwashers in general are going to be standard size unless you get a portable dishwasher or a 30 inch wide dishwasher. There are very few of these models. Your size dishwasher is just 24" wide 24" deep and 34 1/2 inches tall but the height can be adjusted somewhat
