20 Most Recent
Maytag MAV5920E Top Load Washer Questions & Answers
The washer gets unbalanced on small loads that
the problem with small loads is that the tub gets unbalanced very easy,if it spins correctly with a larger load there's nothing wrong with the washer,it's just unbalanced,you can open the lid and move the clothes around by hand to try to balance out the load,very common,also has the washer been moved?check for level,if it was moved one of the legs could have moved to put the washer unlevel,
Similar Problem on the Kenmore 500 series
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question%%&&^$
I have a maytag MAV5920EWW and i need to know how
Hello there:
here isa couple of links below that will show you how to do it ok
I hope that this is very helpful for you
Best regards Michael
[PDF]
16026502 Maytag Amana Top Load Washer
8628k - Adobe PDF - View as html
MAV5920EWW. MAV551EEWW. NAV8805EWW. Electronic. Energy Star rated. ... "Agitator/Spinner/Outer Tub/Transmission Removal" procedure. ...www.servicematters.com/maytag_library/docs/16026502.pdf
[PDF]
Technical Bulletin
1950k - Adobe PDF - View as html
MAV4758AWW, MAV551EEWW, MAV5758EWW, MAV5920EWW, MAVT236AWW, MAVT346AWW, MAVT446AWW, MAVT546EWW ... 4. Remove Agitator by loosening bolt threaded into ...www.servicematters.com/maytag_library/docs/TDL-0086-B.pdf
Kenmore 600 with atc. water temp change
to change water temp when a cycle has started, pull the knob and reset the water temp, then move the dial to the desired setting. push knob in. resolved by trial and error!
Maytag MVW7232HW0 top load, error codes and condensation on control panel when using hot watet
1. ERROR CODES: CHECK THE USER MANUAL FOR THE WASHER TO IDENTIFY THE SPECIFIC ERROR CODES BEING DISPLAYED. THIS WILL HELP YOU PINPOINT THE ISSUE AND TAKE APPROPRIATE ACTION, SUCH AS RESETING THE WASHER OR CONTACTING CUSTOMER SUPPORT.
2. CONDENSATION ON CONTROL PANEL: IF YOU'RE EXPERIENCING CONDENSATION ON THE CONTROL PANEL, IT COULD BE DUE TO THE HOT WATER TEMPERATURE OR THE HUMIDITY LEVEL IN THE ROOM. TRY USING WARM WATER INSTEAD OF HOT WATER TO SEE IF THAT REDUCES THE CONDENSATION. YOU CAN ALSO TRY INCREASING VENTILATION IN THE ROOM TO HELP DISPERSE THE MOISTURE.
Fix for error code E02F06 on Maytag mhw7000xw front load washer
I found this reference on the web ... from a repair technician on a Maytag Maxima>>>
So I'm really sorry to bring you this bad news, but let me explain your error codes. F06 E02 is a communication error between your MCU (motor control unit) and your CCU (central control unit). You'll want to remove the top panel, the control panel, and then the front panel of the washer and make sure the wire connections to the motor control unit below the tub are all secure. If everything checks good, you'd need to have the MCU replaced.
From a different reference on a similar Maytag MHW6000XW2 ... also indicating communication issue
Usually ... hidden somewhere on the inside of the washer you will find the service technician paperwork which has all sorts of additional detail.
Helpful?
Good luck on your troubleshooting!
Maytag top loading washer with UL code
Leveling: Ensure the washer is properly leveled. An unbalanced load can trigger the UL (unbalanced load) code. Use a level to check if the machine is sitting evenly on the floor.
Load Distribution: Make sure the clothes are evenly distributed in the drum. An imbalanced load can cause the UL code to appear.
Calibration: Some models have a calibration mode that can be accessed through the control panel. Running a calibration cycle might help the washer to detect load balance more accurately.
Electronics: There could be an issue with the control board or wiring harness. Inspect these components for any visible damage or loose connections.
Professional Service: If none of the above steps resolve the issue, it may be time to consult with a professional appliance repair technician who can diagnose and fix the problem more accurately. They may have specialized tools and knowledge to pinpoint the exact cause of the UL code.
Where is the counterweight in my Maytag washer model MVWC565FW2
If yours is a top loader it will mounted near the drum inside the machine. It will be a shaped block of concrete curved to sit close the actual drum. The most like places will be at the front, nearest you when your putting clothes in it, at about 3/4 of the way off the floor. It could also be in a similar place at the back of the machine.
