20 Most Recent Maytag MAH6700AWW Neptune Front-Load Washer Questions & Answers
Check if the "locked"or "door locked" light comes on. If it does not, you need to replace the wax motor in the door lock assembly and the machine control board, which is inside the control panel. The control board is expensive, so instead of buying the whole control board, if you're good in electronic repair and soldering, try checking ebay for the control board repair kit. Search for "MAYTAG NEPTUNE WASHER R11 Q6 REPAIR KIT". It has all instructions how to do the repair. Good luck!
Maytag... | Answered on Oct 09, 2019
I just had this problem come up this morning. I turned the machine off, then started again. It works fine! This is what my Maytag looks like.
Maytag... | Answered on Oct 15, 2018
Have you checked lid switch? If bad, unit will not spin and drain.
Maytag... | Answered on May 28, 2018
If washer hums when it should spin, and the washer will not drain, you may have 2 issues.
First check that the drain pump, drain hose, and wall drain are free of debris.
The washer may not spin properly if the drain system is not operable.
Once you are sure the washer drain pump, drain lines, wall drain, and drain hose is okay, run a test wash.
If the washer hums but now drains, you fixed one issue.
If the washer still hums, you may have a bad belt, motor coupler, motor itself, etc...
Check parts for wear and replace as necessary.I pulled the drain impeller and found a sock from my little guy stuck in there. Fixed!
check all water outlets to make sure there is nothing blocking the pipes.
you could also go to this link it might help you out..... Washer does not remove water in final spin Google Search
Maytag... | Answered on Oct 24, 2017
sadly we make no physical repairs like a repair shop will .
Maytag... | Answered on Oct 20, 2017
Always supply a model number, each model has it's own foibles. It is very hard to assist without full details, sorry.
Maytag... | Answered on Oct 03, 2017
The E2 shows that there is a motor problem. This can be caused by having an extra heavy load in the machine so take some out and try it. It can also be cause by any iof the buttons being stuck so make sure they are all 'free'. If this fails then you will need to have a new motor and call a repair man unless you can do the job yourself.
Maytag... | Answered on Jun 05, 2016
Fuse open ... must meter all the fuses in the back. Use an ohm meter.
Maytag... | Answered on Jun 02, 2016
Use a Wet and Dry vacuum and vacuum the water out, or use a Siphon hose.
Maytag... | Answered on May 25, 2016
Could it be one of the valves? My LG front loader had problems with one of the electronic valves not opening and closing properly.
Maytag... | Answered on Dec 09, 2015
I assume you have water coming out of the dispenser and running down the front of the machine. You probably have a build up of soap powder in the water inlet and it is restricting the flow and backing up.
Soap powder is only partially soluble in cold water and a residue of undissolved powder builds up over time, one of the reasons I use a liquid detergent. Remove the dispenser tray, it should pull out fairly easily with just a little resistance. Try and clear any blockages, hot water is best as it dissolves better. Clean the tray you have removed and re-assemble.
Maytag... | Answered on Dec 07, 2015
a slow spin sometimes indicates that a out of balance switch might be malfunctioning
Maytag... | Answered on Nov 01, 2015
Maytag MAH6700AWW Neptune Front-Load Washer Logo
520 questions posted
Top Maytag Washing Machines Experts
jimorris77
Sheldon Dedek
Bill Long
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
Neptune Maytag
  • Neptune Maytag
Most Popular Question
poaring water from soap dispenser
  • Washing Machines
