20 Most Recent Maytag Dependable Clean Top MAV5920EWW Top Load Washer Questions & Answers
Burning smell and smoke from motor
Sounds like the transmission is jammed.  This will cause the motor to bog and burn.
5/29/2014 7:09:54 PM • Maytag... • Answered on May 29, 2014
0answers
0answers
Won't drain during spin cycle and leaks
You need to replace the drain pump on your unit. I see this problem about 8-10 times a month with this model. The repair is simple and will only take you 10-15 mins. Here is the part to order.Here is a video I found to help you make the repair.
9/7/2013 11:10:00 PM • Maytag... • Answered on Sep 07, 2013
Maytag washer # MAV5920Eww. Too much water remains after spin cycle. How to repair.
Can you create custom programs? On my top load washing machine I add additional spin cycles to the program.
1/8/2013 1:22:39 AM • Maytag... • Answered on Jan 08, 2013
Maytag dependable care LAT8435AAE fills with water
You need a new timer. It's an easy repair ...http://www.repairclinic.com/Maytag-Washing-Machine-Model-LAT8435AAE-ID-90821-Circuit-Board-Timer-Parts
11/11/2012 7:33:03 PM • Maytag... • Answered on Nov 11, 2012
Maytag washer out of balance
First make sure on the machine that all adjustable legs under neath are touching the floor and it is level if all is good. THis could be a case that the weight that balances the machine inside is either loose or off this is a big steel weight or a concrete weight under neath the machine and behind its cover from the rear. This has to be opened up to see what it actually wrong. Please dont forget to rate my solution and leave testimonial this is how i earn my achievements . Thanks in advance
4/25/2012 6:41:28 PM • Maytag... • Answered on Apr 25, 2012
0answers
0answers
I would like to change
http://www.kitchenaid.ca/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%202206671.pdf
4/28/2011 5:22:49 PM • Maytag... • Answered on Apr 28, 2011
I have a brand new
I had this one come up on a washer I had professionally installed for a client. When I looked into it I found there were shipping blocks made of squeaky Styrofoam the installers left in place. Only made the noise when it was full of water and working hard shifting back and forth in agitation. It said right in installation instructions to take the shipping blocks out too.
2/20/2011 11:30:05 PM • Maytag... • Answered on Feb 20, 2011
Mav5920eww lights on, would only buzz, would not
washer only fills about a cup of water and stops, works on spin
2/1/2011 10:31:46 PM • Maytag... • Answered on Feb 01, 2011
0answers
Washer is making loud noise, only in wash. No
there is a good chance it does but you can check the transmisson coupler and make sure it is in good shape.this coupler is located inbetween the motor and the transmission. checking this may help in the long run you may need to replace the transmission.
you can also remove the inner tub and make sure there is nothing stuck in there that would cause this problem
9/19/2010 11:11:52 PM • Maytag... • Answered on Sep 19, 2010
When my washer spins or if you lift the lid before
That is the braking mechanism in the transmission. Not usually worth fixing but will probally last quite a while.
6/11/2010 6:28:47 PM • Maytag... • Answered on Jun 11, 2010
Maytag Dependable Clean Top MAV5920EWW Top Load Washer Logo
27 questions posted
Top Maytag Washing Machines Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
ZJ Limited
ZJ Limited
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Maytag Washing Machines
Most Popular Question
drain during spin cycle leaks
  • Washing Machines
