it could be that you have somthing stuck in the pump or outlet hose I went to a machine the other day and it had a intermitent fault like yours and it was a coin stuck in the drain hose on the pump when it washed in cold it was ok but when it was a hot wash it expanded the hose enough to allow the coin to flap up into the pump outlet hole hope this might help you
Hello Stacey, W/D here. Yes, it can be a fill valve, usually called a solenoid valve. The easiest way to determine which one it is would be to close one of the water supply valves to the washer (one of the faucets at the wall). Close it when you have a slight level already in the washer, and watch the level. If the level continues to rise, the water is coming down the opened line, and that solenoid would need to be replaced. Best regards, --W/D--
To find where the leak is coming from, remove the 2 bottom bolts on the lower kick panel and remove panel. Next, remove the 2 bolts holding the upper front panel and remove it also. Now, with the front panels removed, run the washer and look for where it is leaking from. Repost your observations.
If nothing is worn in that pulley/cam area then the transmission has gone out. Thanks, please leave feedback or contact me again for more info if you need it.
I found this reference on the web ... from a repair technician on a Maytag Maxima>>>
So I'm really sorry to bring you this bad news, but let me explain your error codes. F06 E02 is a communication error between your MCU (motor control unit) and your CCU (central control unit). You'll want to remove the top panel, the control panel, and then the front panel of the washer and make sure the wire connections to the motor control unit below the tub are all secure. If everything checks good, you'd need to have the MCU replaced.
From a different reference on a similar Maytag MHW6000XW2 ... also indicating communication issue
Usually ... hidden somewhere on the inside of the washer you will find the service technician paperwork which has all sorts of additional detail.
Helpful?
Good luck on your troubleshooting!
Leveling: Ensure the washer is properly leveled. An unbalanced load can trigger the UL (unbalanced load) code. Use a level to check if the machine is sitting evenly on the floor.
Load Distribution: Make sure the clothes are evenly distributed in the drum. An imbalanced load can cause the UL code to appear.
Calibration: Some models have a calibration mode that can be accessed through the control panel. Running a calibration cycle might help the washer to detect load balance more accurately.
Electronics: There could be an issue with the control board or wiring harness. Inspect these components for any visible damage or loose connections.
Professional Service: If none of the above steps resolve the issue, it may be time to consult with a professional appliance repair technician who can diagnose and fix the problem more accurately. They may have specialized tools and knowledge to pinpoint the exact cause of the UL code.
Ld is long drain, so either the pump is blocked, the pump impeller is worn or the drain hose is blocked.
I had a drain blockage on a Miele and it was cause by an apple stalk lodging itself across the ridges of the drain hose and had collected enough lint to block it, This was a machine that was washing towels commercially for 16 hours a day.
Unhook the drain and watch it pumping either into a bucket or into a laundry sink. It should fly out in a jet!
If yours is a top loader it will mounted near the drum inside the machine. It will be a shaped block of concrete curved to sit close the actual drum. The most like places will be at the front, nearest you when your putting clothes in it, at about 3/4 of the way off the floor. It could also be in a similar place at the back of the machine.
