20 Most Recent
Maytag MDG6400 Atlantis Gas Dryer Questions & Answers
Wont get hot
If the dryer runs the same as before except it will not get hot then check your heating element that is more than likely your problem.
MY DRYER STOP DRYING WHAT IS THE PROBLEM
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
No heat in dryer
Hello there Here are some ideas that may help you
- Things that could stop a gas
dryer from heating:
- glow bar igniter, thermal
fuse ( not all models ), coils on the
gas valve, gas valve, thermostats, motor
heat switch, timer, selector switch,
sensor.
On the back of the dryer
near the fan blower housing is a thermal
fuse, if this opens up ( no continuity
) the gas burner often quits but the motor will still run. If the thermal fuse
is open/bad, always clean, change, adjust the venting system and vent hood first
and clean out the dryers air ducts. Sometimes it is a good idea to replace the
operating thermostat at the same time.
Thermal
fuse parts help link...on blower housing cover, can not be re-set, must be replaced
if is open (no continuity between pins).hope this is very helpful for you
best regards Michael
Gas dryer seems to be overheating
The first and easy thing to check is the vent going out of the house if it is restricted or cloged it will over heat and shut off check that first
Maytag MVW7232HW0 top load, error codes and condensation on control panel when using hot watet
1. ERROR CODES: CHECK THE USER MANUAL FOR THE WASHER TO IDENTIFY THE SPECIFIC ERROR CODES BEING DISPLAYED. THIS WILL HELP YOU PINPOINT THE ISSUE AND TAKE APPROPRIATE ACTION, SUCH AS RESETING THE WASHER OR CONTACTING CUSTOMER SUPPORT.
2. CONDENSATION ON CONTROL PANEL: IF YOU'RE EXPERIENCING CONDENSATION ON THE CONTROL PANEL, IT COULD BE DUE TO THE HOT WATER TEMPERATURE OR THE HUMIDITY LEVEL IN THE ROOM. TRY USING WARM WATER INSTEAD OF HOT WATER TO SEE IF THAT REDUCES THE CONDENSATION. YOU CAN ALSO TRY INCREASING VENTILATION IN THE ROOM TO HELP DISPERSE THE MOISTURE.
Fix for error code E02F06 on Maytag mhw7000xw front load washer
I found this reference on the web ... from a repair technician on a Maytag Maxima>>>
So I'm really sorry to bring you this bad news, but let me explain your error codes. F06 E02 is a communication error between your MCU (motor control unit) and your CCU (central control unit). You'll want to remove the top panel, the control panel, and then the front panel of the washer and make sure the wire connections to the motor control unit below the tub are all secure. If everything checks good, you'd need to have the MCU replaced.
From a different reference on a similar Maytag MHW6000XW2 ... also indicating communication issue
Usually ... hidden somewhere on the inside of the washer you will find the service technician paperwork which has all sorts of additional detail.
Helpful?
Good luck on your troubleshooting!
Maytag top loading washer with UL code
Leveling: Ensure the washer is properly leveled. An unbalanced load can trigger the UL (unbalanced load) code. Use a level to check if the machine is sitting evenly on the floor.
Load Distribution: Make sure the clothes are evenly distributed in the drum. An imbalanced load can cause the UL code to appear.
Calibration: Some models have a calibration mode that can be accessed through the control panel. Running a calibration cycle might help the washer to detect load balance more accurately.
Electronics: There could be an issue with the control board or wiring harness. Inspect these components for any visible damage or loose connections.
Professional Service: If none of the above steps resolve the issue, it may be time to consult with a professional appliance repair technician who can diagnose and fix the problem more accurately. They may have specialized tools and knowledge to pinpoint the exact cause of the UL code.
Where is the counterweight in my Maytag washer model MVWC565FW2
If yours is a top loader it will mounted near the drum inside the machine. It will be a shaped block of concrete curved to sit close the actual drum. The most like places will be at the front, nearest you when your putting clothes in it, at about 3/4 of the way off the floor. It could also be in a similar place at the back of the machine.
