20 Most Recent Maytag MSD2650H Side by Side Refrigerator Questions & Answers
Try adjusting the controls if you havnt already or if that doesnt work remove all of the ice that will have built up inside as this massivly affects performance. Hope this helps.
Maytag MSD2650H... | Answered on Oct 20, 2012
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Maytag MSD2650H... | Answered on May 27, 2010
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Maytag MSD2650H... | Answered on May 24, 2010
Your model Maytag comes with an electronic ice maker and if you just recently changed the water filter the water should be dispensed for 2 or 3 minutes or until any air that may be trapped in the lines is removed. If air is sill present in the filter the ice maker opens the water control valve for about 7.5 seconds. If air that is what the ice maker will get until the air is completely purged from the system. If you fill that you have past that point then pour tap water into the ice maker and let freeze. After the water freezes the ice maker should cycle and dump. If not the the ice maker core may need replaced. If yes it dumps then the air may not yet purged or the water control valve for the ice maker side may be defective. This is one of those wait and see repairs. I will send you a link to the copy of the service manual and page 71 begins addressing the ice maker. Thanks, Sea Breeze
Maytag MSD2650H... | Answered on Dec 23, 2009
Water Filter Status Indicator
Light (select models)
The Water Filter Status Indicator Light serves as a
reminder to replace the water filter. A green light
indicates that the filter is in good condition. A red light
indicates the filter should be changed. Once light turns
red, it will remain red until function is reset.
To Reset Indicator:
• Press and hold both the Lock and Water
buttons simultaneously for four seconds. The
green filter status indicator light will flash
three times when the function has
successfully reset.
Sea Breeze
Maytag MSD2650H... | Answered on Nov 26, 2009
That model has what is called a adaptive defrost on it this fails very often it is located inside the ref under the control panel, The only other possible cause would be a defrost thermostat, this is located near the heater.
Maytag MSD2650H... | Answered on Aug 11, 2009
Yes you have eather a bad defrost timer, defrost heater, or the drainline could be stoped up. Call a some real Ref. tec people because those don't know what they are doing.
Maytag MSD2650H... | Answered on Aug 04, 2009
Any time moisture freezes to something in the freezer it is two possible reasons that are most likely. The defrost system is defective, blocked or there is outside air being drawn into the freezer from a faulty seal or the ice maker door at the dispenser is sticking open. Keep an eye on these things and freezer temperatures and fresh food temperatures. Your refrigerator is complex and I have the service manual and willing to help you solve this. Thanks, and let me know, Sea Breeze
Maytag MSD2650H... | Answered on Jul 11, 2009
Hi, With the information you supplied i'm going to assume there is an ice build up at the rear of the freezer. Your problem is going to be with your defrost system. I will also assume you have the ability to repair this yourself. This is going to be one of three problems with your refridgerator, 1st thing to do is remove shelfs and panel in the back of the freezer...you should see ice build up on the evaporator...don't worry get a hair dryer and melt the ice. Next locate the wires for the heater...using a multi meter test the heater for condinuity...if the heater is bad replace it, If the heater is good replace the defrost thermostat..the stat normally is a barrel looking part clipped onto the evaporator pipe. The last possible problem could be the evaporator fan, have you heard the fan running in the past few hours?..if you are not sure pull the panel out to where you can see fan and watch it over an hour to see if it turns. I have included links with pictures of what the parts you need to check are: http://romulusappliance.com/manufacturers/maytag/refrigerators/575432.JPG defrost stat http://www.hotekalliance.com/UploadFiles/2008627111553382.jpg heaters http://www.applianceblog.com/archives/EvapMotor1018185.jpg evap fan. Hope this helps. If you have any other questions please feel free to comment again. If you decide to get a repair guy in should not cost you any more then $120 - $200 depending on make/model/problem Good luck!
Maytag MSD2650H... | Answered on Jul 07, 2009
Hi, It sounds like the selonoid that shifts the auger is not working. This part is located behind the panel that the bucket pushes against. The little wire arm on the bucket goes into this. Sometimes they just get froze up from the moister. If you remove the panel/section the selonoid is in, you can see if the part has went bad.
I hope this helps you. Please let me know If I can assist you further.
Vic
Maytag MSD2650H... | Answered on May 23, 2009
Sounds like it might be the thermostat
sensor bulb is defective see if you can
turn the refrigerator off with the thermostat
the defrost heater is supposed to heat up
enough to open the defrost thermostat
Make sure the defrost timer works to
turn on lhe heater & turn off the defrost tstat
turn the power off and check the tstat & defrost
heater for continuity check to see if tstat open
and closes when you turn the knob,
if you remove the tstat you can check the
bulb in ice water and warm water aborv 40
to see if tstat cycles on and off
Maytag MSD2650H... | Answered on Nov 26, 2007
test the supply with a meter
Maytag... | Answered on Dec 23, 2019
Maytag MSD2650H Side by Side Refrigerator Logo
24 questions posted
Top Maytag Refrigerators Experts
Marvin
Marvin
Carlos Alvarez
Level 1 Expert
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
  • Maytag Refrigerators
Most Popular Question
defrost heater not turninh
  • Refrigerators
