20 Most Recent Avanti W789SA Top Load Washer Questions & Answers
My washing machine W797 AVANTI,
need a meter to test circuit and look up online for parts
4/8/2020 11:30:27 AM • Avanti W789SA... • Answered on Apr 08, 2020
My washing machine agaitates to wash the clothes but it does not spin to wring out the clothes at the end of the cycle it just stops
Dear Customer,
I recommend you to follow the below stated routines
  • Test the lid switch
  • Test the timer control
  • Test the centrifugal switch
  • Test the water level switch
  • Inspect the motor coupler
  • Inspect the drive belt (belt drive only)
  • Inspect under the washer for soot (clutch)
  • Test the motor
  • Inspect the pulley
  • Test the transmission
  • And as for the clothes being wet after the spin..This may be a spin problem or a drain problem
    Drain:
    • Make sure the drain line is clear
    • Check the drain hose for a partial blockage
    • Inspect the water pump
    Spin:
    • Test the motor
    Please rate this Solution.. Thank You.. Good Luck..
    5/22/2016 1:25:07 AM • Avanti W789SA... • Answered on May 22, 2016
    Drain hose cracked and leaks water
    You just have to replace it. Try these sites for spares with your model number, etc:
    RepairClinic.com
    espares.co.uk
    AppliancePartsPros.com
    mcminone.com
    3/24/2014 6:09:51 PM • Avanti W789SA... • Answered on Mar 24, 2014
    Washer don't drain the water
    Hi
    Thanks for using FixYa. Usually water not draining at all is due to the drain line that is clogged and/or because of kinked drain hoses that’s attached to the Drain Pump. In many washers, a small sock or other piece of clothing can get between the clothes tub and the outer tub that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that's attached to the pump--or even into the pump itself. If it's in the pump, you need to remove the hoses from the pump and pull the item out. To remove the sock from the outer tub port, open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then, using needle-nose pliers try to grab and remove the clothing through the port. Sometimes you can't remove the stuck clothing from below. Then you have to remove the agitator, top of the outer drum shield, and inner clothes tub. If you think that this isn't easy to do--and you may need special tools—then you might be happier getting a qualified appliance repair technician to do the job. If the drain line isn't plugged, the problem may be with your pump. Even if the pump appears to be turning, the internal impeller may be broken. If so, you need to replace the pump. Please do accept the solution if the issue is resolved or post a comment for further assistance.
    Thanks
    Rylee
    10/19/2013 6:33:51 PM • Avanti W789SA... • Answered on Oct 19, 2013
    2answers
    Wont spin or turn
    It may be a bad belt. Check the spin bearing and the basket drive also. Both of these control the spinning of the machine. If you have a question, let me know. I am here to help you the best I can.
    6/30/2013 5:21:54 PM • Avanti W789SA... • Answered on Jun 30, 2013
    Machine drains water only on the first cycle, after that it doesnt drain out, the water, and that's keeps happening
    i have the same problem what you have i don t know what i do
    3/4/2013 5:02:35 AM • Avanti W789SA... • Answered on Mar 04, 2013
    Smell of stale water from Avanti compact washer
    It may not be draining very well. I have a front load washer and run a cycle of a few cups of bleach through mine every couple months.I also add vinegar to most washes but that's due to my teenage son's athletic wear.Both those things do the trick.You shoudl probably check the mechanics as well but the above is a stop gap.
    9/15/2012 12:14:52 AM • Avanti W789SA... • Answered on Sep 15, 2012
    0answers
    Machine does not drain and spin
    clogged drain check your drain pump
    5/13/2011 12:05:22 AM • Avanti W789SA... • Answered on May 13, 2011
    Where can I find a new drain hose for this
    sears/lowes
    12/30/2010 5:13:29 PM • Avanti W789SA... • Answered on Dec 30, 2010
    Avanti W789SA Top Load Washer Logo
    41 questions posted
    Top Avanti Washing Machines Experts
    Kolbrun...
    john h
    Jorgie  the...
    Jorgie the...
    Are you an Avanti Washing Machine Expert? Answer questions, earn points and help others
    View Most Popular
    • Avanti Washing Machines
    Most Popular Question
    machine not drain spin
    • Washing Machines
