20 Most Recent Beko 324250WN 28" TV Questions & Answers
When turned on picture is red
Video output card [CRT base board] has the fault.
3/6/2015 2:26:06 PM • Beko 324250WN... • Answered on Mar 06, 2015
Turned on TV and picture was red
One color predominant screen. You can get details about this fault by the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
3/6/2015 2:25:29 PM • Beko 324250WN... • Answered on Mar 06, 2015
Remove sub titles
Look for closed captioning in the tv menu.
2/19/2015 3:11:28 AM • Beko 324250WN... • Answered on Feb 19, 2015
Why does my beko television make loud squeaky noises
Check and replace damaged component/s at its horizontal scan output section circuit. Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If the voltage is absent check the feeder resistor; if any. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/
7/31/2014 4:25:00 AM • Beko 324250WN... • Answered on Jul 31, 2014
Hi i need the code for my beko tv
0039,0036,0031. Try these codes. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common codes used for devices too are given, in the order of device brand name list in alphabetical order. Do a search by type in the brand name of your device, at its search box, and press "Enter". Or, pull up older posts. http://remotesearch.blogspot.com/ http://electrohelponline.blogspot.com/
7/22/2014 6:42:18 PM • Beko 324250WN... • Answered on Jul 22, 2014
Front panel lock no remote
To unlock the panel lock, you should have its remote control. If you wish to buy its original remote control, contact the authorized service center, or authorized dealer to your device brand. To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability? Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device you have. Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its user manual. Never accept a remote control, that hasn't both of this. If you see the sites by "MOSAIC" view, will make surf easier. http://electrohelponline.blogspot.com/
2/10/2014 3:22:26 AM • Beko 324250WN... • Answered on Feb 10, 2014
2answers
My beko tv wont turn on there is power running
check inside fuses in rear of tv ...take plug out first...
4/9/2013 2:41:51 PM • Beko 324250WN... • Answered on Apr 09, 2013
Wont Come off Standby
IIC Bus line is busy. Should be a main Digital board problem. Check and replace it.
10/12/2012 3:57:15 AM • Beko 324250WN... • Answered on Oct 12, 2012
How do i zoom out from my beko tv
Download the user manual to this set. It has all details. Click here to download it.
9/1/2012 3:27:11 PM • Beko 324250WN... • Answered on Sep 01, 2012
Will not power up
This can be a failure of the power supply and so check the SMPS unit. If not there is a high possibility that the components over a period of heating and cooling, tend to bring on a problem of dry soldering. So my advice is to check the set for some loose joints that have played on to give you these erratic shut downs or poor performance. The best way to check for loose connections is to tap lightly when the set is powered on, if there is change while tapping then it seems that there are DRY solder joints. Remove main plug, the covers - with caution of high voltage, check for dry joints, and use a good soldering iron to solder all suspected points. Sometimes the fault occurs when the set warms up; if so you can simulate the heat using a hair dryer on the suspected areas, try with the power supply, distribution, Processor controller, driver controllers on the A/V related sections. Also the use a FREEZE-IT spray can simulate the components to cool and show up the fault. It can also be related to WEAK ELECTROLYTIC capacitors as the value can reduce in time. Based on the above method you must be able to locate the area of fault and solder the sections.
10/20/2011 12:26:14 PM • Beko 324250WN... • Answered on Oct 20, 2011
Beko 6167w will not power up
Possible that the power supply has failed. So check your SMPS unit.http://www.fixya.com/support/r5826301-working_switch_mode_power_supplies
10/18/2011 9:59:13 AM • Beko 324250WN... • Answered on Oct 18, 2011
Beko fst.nicam.fastext
LOST THE ROMOTE FOR THIS T.V. GOT A ONE FOR ROMOTE CONTROL BUD ... BUT THE ONE FOR REMOTE CONTROL IS ASKING FOR THE T.V DEVICE CODE COULD ANY 1 HELP ME OUT THERE ??
8/18/2011 10:32:09 PM • Beko 324250WN... • Answered on Aug 18, 2011
Hi, My Grundig Lenaro tv
Hi. I have had the same problem for the last 6 weeks on my Lenaro 32"
Have contacted the Grundig Support and they are balaming it on the Digital Receiver. They say that the receiver component is made by Beko and thay have carried out an Over The Air upgrade which has caused this problem. Grundig contract out their services as this is just a trading name.
Their support is not willing to do anything and say that it is down to Beko.
I am now trying to get hold of Beko. After that I am going to contact trading strandards and Watchdog.
7/13/2011 11:34:53 AM • Beko 324250WN... • Answered on Jul 13, 2011
Hi there! I have
I assume that you have attached it via SCART cable...since SCART plugs have 21 pins, and carry video, audio and switching signals ,sometimes a bad connection on either TV side or Top Box side ,the sound goes off first..Make sure your SCART plugs securely fit to either side.
If it does not help pls visit the URL below for further advise before going to blame the Top Box....
Hope this helps! Take care and please Remember to rate/vote and give me
4 Thumbs Up for me to continue for Helping out the Community :)
Thanks
Set-top Box Connection Advisor This page is designed to help you with connecting your Freeview, BT Vision, Virgin Cable, Freesat or Sky satellite set-top box to your home TV system. http://www.radioandtelly.co.uk/connecthelp.php
7/1/2011 5:31:51 PM • Beko 324250WN... • Answered on Jul 01, 2011
Beko 32wlu530hid keeps freezing everytime
H?,
This problem unfortunately very common on these TV sets..
As far as I examine the case ,I believe a component on the circuit board is not properly working..
Either there is cold soldering on the board or a dead capacitor may cause this.
Sorry but Your TV needs service..I hope you still have warranty to cover this..
Thanks
7/1/2011 12:35:45 PM • Beko 324250WN... • Answered on Jul 01, 2011
Need code for beko tv
can you try these codes ,one should work..
TV/0170 -- TV/0226
Take care and please Remember to rate/vote and give me 4 Thumbs Up
Hope this helps
6/24/2011 2:01:53 PM • Beko 324250WN... • Answered on Jun 24, 2011
2answers
Wont come on
Instead of just unplugging the TV, perform a power drain:
1. Unplug the product's power cable so the device is not grounded to the house. 2. Press and HOLD the product's own power button for 1 minute to drain the capacitors. 3. Plug the product back into a wall outlet and try to turn it on.
Note: This procedure works with battery operated devices as well so remove the batteries and hold down it's power button.  Electricity can remain in capacitors and on circuit boards enough to prevent normal functionality. By clearing the residue electricity, your product will have a fresh start and many times this will resolve a buggy or non-responsive device that appears to be dead.
If the TV still won't turn on, then it appears something is wrong with it's mainboard since the TV is still receiving power because the standby light is still coming on.  The cost of fixing an older TV's mainboard could be costly or impossible if the part is discontinued.
3/29/2011 10:39:29 AM • Beko 324250WN... • Answered on Mar 29, 2011
BEKO TV. MODEL NR32WLH530HID 145
Hi rwd1552,
Power on the unit in the dark room then shine with the flashlight directly in the screen, you will barely see the images. This is because your backlight is not functioning. The following reason is the caused.
1. Power supply - missing B+(supply voltage) coming from this board feeding the inverter board. This is caused by faulty transistor, dried/leaky electrolytic capacitor, open fusible resistor.
2. Inverter board - even the B+ is good from the power supply, if the fuse, driver transistor, driver transformer is faulty no output to the backlight resulting to black picture.
3. Busted backlight - even inverter board is good but if this is busted resulting to black picture also.
Diagnosing the fault is technical and if you don't have necessary tools and test instrument and can't fix it yourself, I would advice you to look for an experienced technician to troubleshoot the symptoms.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
3/27/2011 12:36:08 PM • Beko 324250WN... • Answered on Mar 27, 2011
Picture fading keeps coming and going?
sdfsdf
3/13/2011 10:49:38 PM • Beko 324250WN... • Answered on Mar 13, 2011
Beko 324250WN 28" TV Logo
94 questions posted
Popular Products
Top Beko Televison & Video Experts
ExpressFiX
ExpressFiX
NOEL
NOEL
ADMIN Andrew
ADMIN Andrew
Are you a Beko Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Beko Televison & Video
Most Popular Question
grundig lenaro tv
  • Televison & Video
