20 Most Recent
Maytag 30 in. Admiral LGC1330 Gas Cooktop Questions & Answers
My stovetop all the sudden
Sorry to read about your problem, I hope this helps you out.
you switch is stuck.. try turning back and forth
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
The smell of gas
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
I want to adjust my Admiral LGC1330AD gas cook top
Two thing you need to do.
1) Call your gas company where you are supplied propane and ask them to set you up and they or someone who contracts for them will help you.
So you will need to replace ALL burners including the oven.
2) Call Admiral and ask them about changing to propane and if they have the products
Bake and broil do not work
assuming that the worst case senario has taken place
first thing i would check is ensure i have proper voltage at the outlet, 120 from each side to ground
220 across L1-L2
the elements are the only thing on the range that uses 220v
if you know how to use a mutimeter
you can test both the elements
disconnect the range at teh breaker
take out the screws at the back wall that hold the elements in
pull out about an inch becareful they dont leave much slack on the wires
disconnect on element terminal and apply your leads your looking for continuity, your meter should beep
if not replace the element
if yes, let the element hang ensureing niether terminal touches anything, reconnect the other terminal
now turn the stove on bake if your doing the lower
turn you meter to ac voltage
you should read 220v
anything less than that, your problem is before that
Code S ab on screen
try pressing and holding the clock tab on the erc for 5 secs
this will usually cause the sab to flash 3-4 times and then retrun to normal operation mode
Stove top is hot
i think have an leakage in ur unit,much better to call the tecnician coz its very dangerous for u if u not check asap.
Propane conversion
All gaq cooktops come from the factory ready to be installed to natural gas. If the only gas available is propane the orifices have to be changed. The orifices are product specific and must be ordered for your particular stove.
That being said, if this is a new cooktop you have the answer. If this is a used cooktop and you do not know which style of orifices are installed now just contact your propane company and they will be happy to help you for free.
good luck with this. and please remember to rate my answer.
Cant find pilot or maqnual
contact whirlpool to get a manual but be sure to give them the model number to get the correct one / whirlpool owns maytag now ,,,,,,,,,, you can even contact a sears service company to order one since the do the maytag service.
The smell of gas
call for service immediatly. dont ever mess with a possible gas leak. it is more than likely a slow leak at the shutoff or the safty valve. your local repair company should have a combustible gas detector. to pin point the leak.
New Maytag MGC7430 gas cooktop leaks gas when lit
First it could be leaking from the control knob when it is on . There could be a leak at the base off the burner letting out gas or on the burner line . You need to get back on to your installer or where you purchased the cook top . This basic gas fitting leak detection .
