20 Most Recent
Friedrich CP12C10 Wall/Window Air Conditioner Questions & Answers
Hi, I just bought a Friedrich air conditioner -
The water you hear is the water in in the drip/drain pan. In most cases, that sound is normal. However, if you don't have the rear of the unit tilted down at least 1/4" to 1/2", the water can not reach the drain hole and drain away, as it should. Correcting that should help solve the other issues you mentioned.
Hope this helped you and thanks for choosing FixYa.
8/2/2011 12:01:23 PM •
Friedrich...
Answered
on Aug 02, 2011
The unit freezes up
When a AC freezes up the most likely reason is that the evaporator coil (the one the cold air comes from) is 'dirty,' and/or the filter (that goes in front of the coil) is also 'dirty.'
Be sure to defrost the unit (if it isn't already).
If it presently has ice on it - just turn the unit to FAN ONLY and allow it to completely defrost (all ice gone).
Then: Be sure the filter is 'clean' and air can flow through it.
Be sure the coil is also clean.
Note: if the coil is dirty you can usually clean it fairly easy with a brush. Often (especially if the unit is freezing up) you can actually 'peel' a layer of 'wet matted stuff' from the coil by hand.
Another reason (less likely one) for the unit freezing up - is that the fan motor is going off (when it shouldn't) and the "lack of any air" over the coil is causing the unit to freeze up. You didn't say anything about the fan motor not running so it's not likely this is your problem - but be aware - that fan motors can get hot and will go off on internal overload - UNTIL - it cools down and then will come back on - so - if you're not watching - it's possible the motor could be "heating up and going off (for 30-90 minutes) and coming back on" without you realizing it, which would cause the unit to freeze up. Like I said - this is not likely though. If, however, it is doing something like this - the 'sure-cure' is to replace the motor. The cost to replace a blower motor will be somewhere in the neighborhood of $200 which should cause one to think about buying a new unit.
Another reason - also 'less likely,' is that the AC is 'low on refrigerant.'
If - after checking the filter/coil - you find that they are both clean and not causing the problem - and you've watched the fan motor and it's not going 'off and on,' then, you must consider that the unit is 'low on refrigerant,' which will require a Service Tech - who has the expertise and tools to repair the leak and re-charge it. If this is the problem you're probably looking at a repair bill of $75 -$125 - which when considering the price of 'new air conditioners' might cause you to think about buying a new one.
Hope this helps.
7/6/2010 12:26:46 AM •
Friedrich...
Answered
on Jul 06, 2010
Fan does not come on when in high heat
that speed in the motor has burnt out. The motor is built wiuth several different speeds on it and it sound as if the speed for the high heat cycle has burnt out. The other speeds will work however it will only be a matter of time before they fail also. Good Luck on your repairs hope this helped you somewhat
Dave
11/11/2009 7:26:05 PM •
Friedrich...
Answered
on Nov 11, 2009
White dust
if the unti working good and cooling then change the filter it may be too old.
9/8/2009 10:50:08 PM •
Friedrich...
Answered
on Sep 08, 2009
My ac unit is making
When you took the old capacitor off did it have the same type of connections as the new one? If so you should have written then down, or remembered the color coding. If it's different then something is wrong. You will probably have to contact the manufacturer of the AC unit.
Please me know what the manufacturer is, or give them a call.
Thanks
Tim
7/18/2009 4:16:55 AM •
Friedrich...
Answered
on Jul 18, 2009
