20 Most Recent
Tektronix Refurbished Phaser 560 Color laser printer -29119 Questions & Answers
Tektronix 540 error 32
Error 32 is most often caused by the cleaning blade clutch grease gumming up. Clean it completely with isopropyl alcohol and a lint free cloth and cotton buds. Re lubricate it with high temperature auto synthetic grease - make sure it has no mineral content.
9/21/2012 5:24:49 PM •
Tektronix...
Answered
on Sep 21, 2012
Hi I have a TEK Phaser 560 Printer that displays Error 32
There's a solenoid under the control board that actuates a stop for the cleaning blade shaft. The open cell foam the factory used to quiet the noise deteriorates with time leaving a sticky residue from the double sided tape.
Pick all the residue off and clean both the solenoid shaft and the metal plate. If you're concerned about noise, put some electrician's tape on the plate. But you might be going in for that falling off down the road. :p
5/12/2010 9:28:32 PM •
Tektronix...
Answered
on May 12, 2010
Jam At A
printers have sensors that tell the main board where the paper is, if a sensor is stuck or broken it will say jam, the question is where "A" is, look in the manual and see if you can find it, it will be either an optical or moving plastic.
hope this helps
good luck
1/7/2008 1:16:53 PM •
Tektronix...
Answered
on Jan 07, 2008
Printer error code 61 on
Hello Sancorp,
In order to provide you a better solution I request you to provide me the opearating system you are using and also the make of the computer.
Thank you.
I have a Tektronix Phaser
This is from the 560 manual hope the codes are the
same. The 560 manual states : Accumulator belt cleaning blade movement
error.
1. inspect the cleaning blade{located on the imaging unit,along
the bottom of the green OPC belt. Is it flipped up? If you cannot flip
it down, replace the imaging unit.
2. Inspect the wiring harness
leading from the cleaning board to CN18 of the engine control board.
3. Replace the cleaning board.
4. Replace the engine control board.
If the above info does not match your model call :
(800) 833-9200 Press 3
(503) 627-2400
