20 Most Recent Pioneer AVIC-X1R CD Player Questions & Answers
Is there sound?
Pioneer AVIC-X1R... | Answered on Feb 27, 2011
you have to make sure that the parking brake wire is connected. in other words grounded
Pioneer AVIC-X1R... | Answered on Dec 15, 2010
hello,the cd player that does not read cd's properly,it's simply because of a weak or bad laser lens,so all you need to do is to get a new laser lens and replace it with the faulty one and you will have your cd working as normal.
the one that will not turn on properly,
this is simply because the power I.C is weak or bad,so it has to be replaced so as for you to have it power on properly...
wish you good luck,
take care.
Pioneer AVIC-X1R... | Answered on May 18, 2010
the oil light can be 4 typs of fluid.. The Transmission, engine, brake and power steering fluid,, Check them all...
If they are all fine then chances are the oil level sensor is bad and needs changing..
Pioneer AVIC-X1R... | Answered on May 15, 2010
Check flexi cable to the screen[issue with the AVIC-X1 range and pioneer service centres have been replacing them free of charge if the head unit's under 4 years old].OR it might be with monitor PCB to get fixed.OR give a Call to 020 8845 1525(Go this Link). OR For Service manual Link(Payment required). Hope this Helped you..Thanks for Contact FixYa..
I think the only hope for this one will be Pioneers direct mate, i cannot find anything on Ebay, Sorry.
Pioneer AVIC-X1R... | Answered on May 06, 2010
does your headunit have a usb if so try and put the cd on a flash drive and try it that way
Pioneer AVIC-X1R... | Answered on Jan 12, 2010
The problem is the disc. It is most likely warped. I had the same issue and I actually removed the unit from the dash still connected, tapped the top and pushed the eject button and out came the disc. I played a little longer and reinserted the disc and it showed the error again, tapped it and ejected it then tried another disc and no problem at all. I tried several and they all worked and every so often tried the original one and it showed error each time. It seems as though the fact it was warped it was catching the unit or a sensor was seeing it as a problem and not allowing it to eject. Hope this helps
Pioneer AVIC-X1R... | Answered on Sep 23, 2009
Call 1-800-pioneer and ask for technical support.They are good!
solutiondoct
Pioneer AVIC-X1R... | Answered on Nov 06, 2008
1-800-pioneer.Give out your model to the tech.,and he will tell you the part that you need.
Tuesday-Thursday between 7-8am would be the best time to call!
solutiondoct
ribbon gone, common problem cost £120 to fix (don't know why cos ribbon only cost £35), just got mine fixed
Pioneer AVIC-X1R... | Answered on Oct 24, 2008
Pioneer AVIC-X1R CD Player Logo
33 questions posted
Top Pioneer Car Audio & Video Experts
Marvin
Marvin
Sumeet Sodhi
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Pioneer Car Audio & Video
Most Popular Question
pioneer avicx1r when try eject
  • Car Audio & Video
