20 Most Recent
Kyocera Mita KM-2530 Laser Printer Questions & Answers
Error (0x4803)
I had the problem that suddenly scan to email did not work anymore. After trying different email provider and all the tips in the internet, I recognized that the time was not in sync. After correcting the time of the printer (settings -> date/time), everything worked fine again.
Scan to folder problem
Delete your Driver for this multi, I use revo-uninstall a free removal tool that cleans the registry. Then download the up to date driver package and reconnect your device.
Regards
Sir Dana Taylor
Kyocera mita km2530 paper misfeed jam00
This usually means that no paper has been fed from the paper cassette or the machine was turned off when you had a paper jam.Remove the paper cassette from the machine and ensure that nothing is stopping the paper from feeding.Also look into where the machine locates in the copier to ensure that no paper is jammed behind the cassette.The paper feed rollers may need cleaning or replacing.
Kyocera Mita KM-2530 error close front coveR
The front door switch or actuator is broken or the door may be warped .Have you tried putting pressure on the front cover? as this may help to indicate if the switch is faulty.
