20 Most Recent
AEG 3.32 cu. ft. / 94 liter Upright Freezer AG788504I Questions & Answers
Alarm
the alarm is there to warn you that the freezers not up to set tempature.. The reason as I see what you wrote would be a stuck or burnt out auto defrost timer motor. or the units got a leak in the refrigerant line??? good luck
Freezer wont go below -9 degrees
This information does not mean anything to us if you didn't specify the model. In what temperature range a freezer works we knew thanks to the stars.
One star (-6 degrees centigrade) is perfect for making ice cubes and is sufficiently cold to keep food for three or four days.
** Two stars (-12 degrees centigrade) stores food for fifteen to twenty days.
*** Three stars (-18 degrees centigrade) will keep food safe for up to three months.
**** Four stars (below 18 degrees centigrade) means that the compartment provides the ideal conditions for freezing down fresh and pre-cooked foods.
Dado
12/20/2022 10:16:11 PM •
AEG Freezers
Answered
on Dec 20, 2022
Fridge water sound
This kind of noises produced gas in cooling system.
In the old coolers never heard sounds like streaming water because the compressors were very loud due to high pressures (12 bars or more), which were required for efficient cooling. Today we use more ecological gases which work (from 5 to 6 bars) at much lower pressures, thus compressors produce much less noises and now suddenly we hear sounds that never before heard. Generally speaking noises is lower, measured in decibels.
Dado
1/6/2015 2:15:06 PM •
AEG Freezers
Answered
on Jan 06, 2015
Freezer losing temperature
Hi Julie. I'm Roger. It sounds like the operating thermostat is not working When not in the fast freeze mode. Can you here a click sound from the thermostat when turning the temperature up and down short of fast freeze? We normally charge them to operate at -10 to -20 degrees. The inside temperature will normally only reach a temperature around 18 degrees warmer. The operating thermostat should allow you to regulate its temperature any where from that capability up to where you want it. See if your thermostat makes a clicking sound when adjusted. The warning light comes on because it knows the box temperature is higher than it is set for and is warning you of that. If it uses a printed circuit (PC) board, the click will dot be very loud. listen closely. Let us know how this turns out for you. We have very good refrigeration techs. here. Someone else here may have an idea too.
1/25/2014 4:49:59 AM •
AEG Freezers
Answered
on Jan 25, 2014
