20 Most Recent
AEG 23 in. 6410KF-N Electric Cooktop Questions & Answers
I Bought Prestige induction stove
E5 or E0 means that the stove is getting overheated. You have to reduce the temperature for it to stop. It goes on with few beeps and then stops.
Aeg hob
It is child lock.
Turn cooker on, press two + at front of oven, this will then take it off for that cooking session.
To turn child lock off switch on hob, and touch - for 5 seconds.
My prestige induction cooktop PIC
It is possible that there is fault in the circuit as the drive section seems to fault when the current requirement is high. It is also possible that there is a component possible a semiconductor- MOSFET- that has gone weak during the power outage and so fails .
It is best to have it checked now as it might save a larger expense if the whole unit fails. Also someitmes it can be a silly dry soldering which can be done up immediately. So get support if youa are not able to DIY.
Turn hob on and only get letter L on each hob and
child lock is activated , switch on hob press - and + button simultaneously hob will return to normal. if zeros dont appear try pressing and hold - key slightly before pressing +key hold both for a few secs.
Hob not working
It is child lock.
