20 Most Recent Durabrand DUR7 Portable DVD Player Questions & Answers
4answers
There is no sound
Have you recently used headphones in this device? I have a portable DVD player that had a similar problem. It thought that headphones were plugged in and that turned the sound in the external speakers off. If i plugged in headphones the sound worked in them. So I jiggled the headphone plug in while in the jack and removed it and the sound came back on.
3/5/2020 3:56:17 AM • Durabrand DUR7... • Answered on Mar 05, 2020
2answers
No sound coming out of the Portable DUR7
is it from the tv no sound coming it mabe be due to faulty cable or due to the wrong connection to the tv do check the Manuel for the connection there is no problem with the dvd player
2/18/2020 2:09:34 PM • Durabrand DUR7... • Answered on Feb 18, 2020
2answers
Adaptor not working?
You need a transformer-type adapter that takes an input of 220-240V and steps it down to 120V output. If you bought the unit in the USA, you may have a problem if it is NTSC-only and doesn't have a NTSC-PAL switch to select the correct video format for India.
12/21/2017 6:03:48 PM • Durabrand DUR7... • Answered on Dec 21, 2017
2answers
I have an ASTAR portable
A breakdown of the insulating material between the capacitor plates will do it. Th capacitor should be replaced with one about the same characteristics. An electronic parts suppler will help you identify a replacement.
12/19/2017 10:23:40 PM • Durabrand DUR7... • Answered on Dec 19, 2017
Sylvania SRD4900 DVD/VCR combo problem
There's a problem with the tape drive, so it's shutting down to prevent damage to the tape. Someone familiar with VCR mechanisms would probably have to see it in action to identify what's wrong. Most of them act in a similar fashion, so if you have a working VCR, you can take the cover off and watch it load a tape, run it, rewind and eject, then compare with the non-working unit. The parts won't be interchangeable, but the tape loading will look much the same. You can comment on what happens and I can try to explain what I think is going on. Better yet, if you could post a video of the internal mechanism while it tries to load a tape, that would be very helpful.
8/6/2017 1:37:02 AM • Durabrand DUR7... • Answered on Aug 06, 2017
My player was mfg in 2005 and has never been used. Do you think the rechaegeable battery pack is still good?
How would we know? Just use a compatible charger to fully charge and see if the battery holds a charge. I’m happy to help further over the phone at https://www.6ya.com/expert/donald_f2ed37026a3ac881
5/21/2016 12:55:58 PM • Durabrand DUR7... • Answered on May 21, 2016
Need a AC 9 Volt power adapter for this unit.
Try this one but it is 250ma be sure that is enough power. I think is is. 9V 250mA Regulated AC Power Adapter By Distributed By MCM MW41 925UC
5/5/2015 9:19:01 PM • Durabrand DUR7... • Answered on May 05, 2015
How do I connect an external fm antenna to a small portable fm receiver. it only has a telescopic rod and no external antenna facility. how do I connect it
If there is no coaxial cable connector on the radio, you simply cannot as a practical matter.
7/19/2014 5:27:39 AM • Durabrand DUR7... • Answered on Jul 19, 2014
0answers
ND630D23976
Be the first to answer 4/21/2014 3:11:40 AM • Durabrand DUR7... • Posted on Apr 21, 2014Be the first to answer
0answers
0answers
Need manual for durabrand dur-10
Didn't anyone take shop in grade school and high school?Get any adapter from another brand name that has the same volts and amps.Keep the old adapter if the new adapter has a different tip use the old one.Simple cut but wires on both adapters like 10-12 inches from the tip.Either use wire strippers or burn off the plastic wait a few seconds so you don't burn you fingers pinch the plastic and pull off the plastic repeat if necess.about 1/2 to 1 inch.The outside wire is the ground wire and there is more plastic under the ground wire.Peel down the ground wire twist the wire together; do the same to the other adapter wire the new one.Get some electricial tape interweve bare ground wires together than wrap the ground wire connection like twice or buy the shrink wrap for radio shack.The positive wire is the inside wire strip the positive on the tip adapter wire that fits your dvd player.Do the same for the new adapter. twist the two positives together than wrap with electric tape. Your done you can go to goodwill as-is stores find the adapter pay 80 cents for the used adapter you save ? $20.I found a Mintek adapter 9v 2.2 amp. that was the same as my DUR-10.Then use the wire stripper or do the same as above
9/6/2012 6:10:01 AM • Durabrand DUR7... • Answered on Sep 06, 2012
I need a replacement rechargeable battery
I would try Google if you have not----most of these battery packs have a generic number right on the label on the battery, did that recently for a friend looking for sealed packs for a large electric scooter, inside found the generic one indicated.
8/28/2012 2:09:26 PM • Durabrand DUR7... • Answered on Aug 28, 2012
How to know when my portable durabrand (dur7) is fully charged
Charge battery for 16 hours before use, and overnight from that point on.
7/8/2012 4:59:30 PM • Durabrand DUR7... • Answered on Jul 08, 2012
Durabrand DUR7 Portable DVD Player Logo
210 questions posted
Top Durabrand Televison & Video Experts
matt martin
matt martin
ZJ Limited
ZJ Limited
Are you a Durabrand Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Durabrand Televison & Video
Most Popular Question
screens durabrand
  • Televison & Video
