20 Most Recent Rinnai Toyostove Direct Vent Heater: Toyostove Laser 73 Shipping Questions & Answers
Hello, I just got an older natural gas direct
Hi John, it should say on the front or somewhere near the control panel what model it is. If you could email a good picture of it to me I might be able to tell. If it is a Monitor heater, go to www.monitor.com or if it is a Toyostove heater go to www.toyostove.com and you can download an owners manual. The most recent models of Monitor gas heater are the GF 3800 and GF 1800. The older one is the GF 500. You can send a picture to [email protected].
11/15/2022 2:37:05 AM • Rinnai Toyostove... • Answered on Nov 15, 2022
Yoyostove laser 73 ee-2 keeps coming up which i
Sounds like your igniter may have burned out. You can test the igniter with an ohmmeter. You can also check for voltage on the circuit board where the igniter connects. Don't try to start it again until you check the igniter because unburnt kerosene will just keep building up in the burner. Let me know if you need more help.
10/26/2022 1:30:37 AM • Rinnai Toyostove... • Answered on Oct 26, 2022
Lazer 56
Hi EJAKFbanks,
I believe by your description and my 8 years experience with Toyo Stove repair that you are missing part of the firing sequence. The firing sequence for a Toyo Stove L 56 is to blink on the burner light for 7-9 minutes, then it clicks up to the medium light (amber-yellow color). The medium light blinks and that is when the fuel pump kicks on and starts to pump. If the stove ignites, the medium light will glow for a second and then drop down to the low light (green) The low light will burn for awhile and at this time you will see a blue flame in the newer heat chamber models or a red glow, and perhaps some blue flame in the older heat chamber models, then the stove will kick up to the medium light for a bit, and then to the high light. An EE6 error code will show only when the flame is extinguished after actually taking place and a burn did occur in the chamber on low. An EE6 is usually one of 2 things: 1. There is an inadequate fuel supply for the stove to maintain a low cycle burn, or the medium, or high. Each cycle consumes more fuel than the prior one. Inadequate fuel supply can be due to a restriction in the fuel line such as icing like cholesterol in a persons arteries, or a plugged sump screen, blocked fuel line or filter, too low a quantity of fuel in the tank, or a fuel line that is not all gravity feed, as in, the fuel line runs down, down, and then up a few feet to get to the Toyo. In that case, the fuel has to rely on head pressure to get to the stove. Head pressure is the atmospheric pressure pushing on the fuel in the tank to force it up against the earth's gravity forces. Solution: You can find any restriction in the line, replace the filters, clean the sump screen, put heat on the fuel line to thaw any icing blocks. 2. An EE6 can be caused by a carbon chain developing from the burner ring, flame sensor or chamber wall to any metal part in the burn chamber. A carbon chain essentially "shorts" out the ground for the unit and the Toyo will shut off on EE6. Solutions:You can bang the side of the Toyo (Old frustrated Alaskan solution) which really just jars the carbon chain loose, clean the flame sensor, clean the fuel nozzle with a straight 3 inch wire, and stick a screw driver in the igniter (red wires) hole and rattle it around real good (another old Alaskan trick). Often, those three things will get your stove running again if it is a carbon chain. The problem will likely occur again, but it will buy you some time until you can get a tune-up done. Most likely, you need a tune-up. Question: When was your last tune-up? Toyo's should be tuned up every 2 years. Tthe book says every one year, but in my experience, every two years is the best bang for the customers buck. The three year mark usually begins showing signs of metal fatigue in other parts of the burn chamber/heat exchanger system so the costs rise a little each year, unless you are a lucky Toyo owner and for some odd reason, your stove can go 3 years between cleanings without any ill effect. If you get your stove running, run it hard on High for about 2 hours to clean and burn all the carbon out. Good Luck! toyotech, North Pole, Alaska
10/20/2020 9:01:43 AM • Rinnai Toyostove... • Answered on Oct 20, 2020
4answers
Toyostove laser 73 heater with a EE 2 error
replace the flame rod. or it could be the computer board for the flame rod. flame rod detects the presence of a flame.
11/6/2017 11:16:38 PM • Rinnai Toyostove... • Answered on Nov 06, 2017
After my stove runs about two cycles, it shows E E 2. we relight and it ignites and then shuts back down with the error message. The tank is full, no air in the fuel line or filter. suggesations?
Has this unit been serviced. Sounds like the Flame Sensor is dirty and not sensing flame OR this actually isn't any flame due to an ignitor or fuel issue. Here is a complete explanation and diagnosis of the EE2 problem: Toyostove Error Code EE2
2/26/2016 5:35:51 PM • Rinnai Toyostove... • Answered on Feb 26, 2016
2answers
Laser 72 is overheating. Top gets too hot to
Check the fan cage on the back, it should be cleaned to allow for adequate air flow. Be sure curtains are not getting pulled up to the fan cage.
This could also be due to a crack in the pot, or if you put too much fuel treatment in your fuel. Regardless of what is causing the overheat situation, an L 72 is a very old unit. You may not want to invest a great deal of money into repairing this unit. The manufacturer has discontinued several parts for the L 72 such as the main circuit board and the burner rings. Without these parts, you are out a heater.
If you can clean the fan cage and remedy the problem, that would be great. If it is a cracked pot, and you decide to replace, be sure that you know how long it has been since you replaced the ring. A ring in a Laser lasts about 7 years. If your technician does not have rings in stock, you could be out of luck when your unit needs a ring.
Be sure to plug the unit into a dedicated outlet and use a quality surge protector with at least 450 Joules to help protect the board. Hope this was of some help. If you have any further questions, visit www.keepuswarm.com. We do have inventory of these discontinued parts for Laser heaters if you decide to repair and your technician cannot get the needed parts.
12/2/2015 8:01:24 PM • Rinnai Toyostove... • Answered on Dec 02, 2015
How do I fix the fan?
The fan's power comes from a multi output transformer.
Either the fan is burned out or the transformer is burned out or the fans moles plug is not plugged in properly.A simple voltage spike or brownout can take out the transformers.
3/8/2015 2:00:32 AM • Rinnai Toyostove... • Answered on Mar 08, 2015
New fuel pump.removed fuel line to burner ,turned unit on very small amount of fuel beinng pumped
Don't forget, the pump does not turn on for 60-90 seconds after the unit starts as part of the start up purging cycle
3/8/2015 1:57:15 AM • Rinnai Toyostove... • Answered on Mar 08, 2015
Where is the flame rod located in a toyo 73
It's the white wire that goes to a metal rod that goes through the can aroind the from of the burner can
3/8/2015 1:52:19 AM • Rinnai Toyostove... • Answered on Mar 08, 2015
Kindly provide owner manual of rinnai gas fan heater
http://www.rinnai.us/customer-care/manuals-literature You can find the manual by model here.
3/2/2015 12:08:43 AM • Rinnai Toyostove... • Answered on Mar 02, 2015
2answers
I was told my Toyostove Laser 72 stove needs to be
I would recomend having a qualified technican service your Toyo.
It IS possible to clean it yourself, but you will want to do it during a time that you aren't needing the heater to keep the space warm.
Certain parts can be hard to tell if they are working as they should if you aren't familar with what you're looking at.
With proper service, your Toyo will operate efficently, and likely last for a long time.
_Helping Hands Services_
- Fairbanks, Alaska -
1/30/2015 6:27:57 AM • Rinnai Toyostove... • Answered on Jan 30, 2015
2answers
Toyostove Laser 73 heater will not run, and the low/med/hi lights flash on and off?
Remove front grille by taking out two screws at lower right and left front sides of stove. slightly pull botom front of grille toward you and lift up and off. Look for two red wires going into burner chamber, the wires will be incased in a gray plastic sheath as they enter chamber. Push on buton like you are trying to start the heater. While it is going through start up process hold the gray plastic sheath with two fingers and see if the sheath does not get warm in a short period of time the igniter is bad and will need to be replaced. This can be cause by water getting into the burner chamber and causing the igniter to crack.
1/30/2015 5:54:22 AM • Rinnai Toyostove... • Answered on Jan 30, 2015
2answers
WHY WOULD THE BURNER GASKET AND IGNITER GASKET BE DRENCHED IN FEL ON TOYO 73, COULD THIS ALSO BE THE CAUSE F NO FLAME IN CHAMBER WINDOW WHEN I TRY TO FIRE IT UP?
If you have too much fuel in the burn pot then you are getting no ignition. Repeated tries to get it to start just dumps more fuel into the pot.
1/30/2015 5:52:35 AM • Rinnai Toyostove... • Answered on Jan 30, 2015
2answers
How do I clean the combustion air intake?
If you are talking about between the outside and the gray flex pipe, remove the pipe and blow the stuff back outside. If it is beyond the gray flex pipe, then a disassembly will be necessary. To prevent further entrance of anything, debris / bugs to either the intake or exhaust, see my modification to the intake/exhaust pipe here: Thread Toyostove Exhaust Bug Shield .
1/14/2015 10:22:42 PM • Rinnai Toyostove... • Answered on Jan 14, 2015
How should I ship a delicate package?
I would suggest that you make a special box for it but it entails a lot work right? I might as well recommend that you browse E Corrugated. They have a wide range of boxes and cases for shipping. You may find something there that suits your requirements. They are a manufacturer of boxes and cases specially designed for shipping whether overseas or locally. You can talk to a staff of the company with your requirements and surely they will have something for you. You also label your box with 'upside down' and 'handle with care' or 'fragile' to ensure that the carriers will know it and ensure that your package is in good hands. Talk to the carrier about it and know how they ship it without being damaged.
12/8/2014 11:15:05 PM • Rinnai Toyostove... • Answered on Dec 08, 2014
Rinnai Tropic ventless heater. Pilot will light
found that the pilot tube had dust bunnys in mine so blew it out with a air can i had for the computer now the pilot light stays on just fine
11/4/2014 9:08:31 PM • Rinnai Toyostove... • Answered on Nov 04, 2014
Does anyone know the size of damper to use on a Toyo L30 with no extention kit installed?
The Part Number for the damper is 20474965 - call your nearest dealer for this part
5/28/2014 4:25:12 AM • Rinnai Toyostove... • Answered on May 28, 2014
Burns orange?
Could be orange for a few reasons could just be burning some dust or something in the air. if it keeps staying orange i would say that it has a cracked heat exchanger and the fan is disrupting the flame.
5/22/2014 12:22:50 PM • Rinnai Toyostove... • Answered on May 22, 2014
Rinnai Toyostove Direct Vent Heater: Toyostove Laser 73 Shipping Logo
278 questions posted
Top Rinnai Heating & Cooling Experts
Paul Carew
Are you a Rinnai Heating and Cooling Expert? Answer questions, earn points and help others
View Most Popular
  • Rinnai Heating & Cooling
Most Popular Question
kindly provide owner manual rinnai gas
  • Heating & Cooling
