20 Most Recent Mr. Heater Natural Gas Garage Heater - 45,000 BTU Questions & Answers
2answers
No spark. My HSU75NG MR. Heater (Big Maxx) will not start on its own. It purges fine ,calls for heat fine, gas flows fine; BUT there is no spark from the Electrode Igniter. Which I have replaced. The
The capacitor in that unit is for starting the motor that drives the blower fan. It has no impact on the ignition of the gas burner. On the control board, there is a light that should be flashing, can you tell us how many times it is flashing?
3/5/2022 8:25:48 PM • Mr. Heater... • Answered on Mar 05, 2022
3 amp fuse keeps blowing
3 amp is this not too small ??
2/3/2021 5:44:38 PM • Mr. Heater... • Answered on Feb 03, 2021
Whats making 3 amp fuse blow at startup?
Short circuited component/s at its internal circuit board. http://electronicshelponline.blogspot.com/
3/27/2018 11:18:25 PM • Mr. Heater... • Answered on Mar 27, 2018
I have a 75,000 BTU Mr Heater and it was working
no gas supply
12/11/2017 9:09:25 PM • Mr. Heater... • Answered on Dec 11, 2017
I have a Mr. Heater
Check the flame sensor is clean . Also check out the pressure switch . Check out the snap disk high and low temp .
10/10/2017 9:59:17 PM • Mr. Heater... • Answered on Oct 10, 2017
I have a mr heater
I would check out the flame sensor it needs cleaning
10/8/2017 11:31:44 AM • Mr. Heater... • Answered on Oct 08, 2017
Mr. Heater Big Maxx 75,000 BTU Heater will not
Is the circuit board giving you a blinking error code?
On a call for heat, the 24 volt thermostat sends a signal to the control module. The control module will indicate a call for heat with a light on the control either blinking or remain solid depending upon model. The inducer (exhaust) blower will purge all gasses from the furnace and pressurize a pressure switch. Once the pressure switch tells the module to continue, the electronic ignition will energize and send 120 volts to the igniter. The igniter will glow and you will be able to see it if viewed thru the small inspection port. Once the igniter gets hot enough, it sends a signal to the module opening up the gas valve (24 volts). Either a pilot will come on or the burner tube will ignite then spread the flame to all burners. Lastly a safety sensor will be looking for a certain temperature within a few seconds and the furnace will continue to operate and the room air blower will turn on in a minute or two.
What could go wrong? The unit will not run if there is no signal from the thermostat (bad thermostat or broken wire), the control module does not sense a signal from the thermostat (bad control), the inducer does not energize (bad motor), the pressure switch does not close (blocked vent piping, bad switch, plugged condensate hose), the igniter does not energize (bad control, bad igniter), the gas valve does not open or there is no gas (bad gas valve, broken wire, no gas), the pilot does not light (dirty pilot), the burner does not light (bad burner, plugged orifice, not enough combustion air), the flame does not spread to each burner (bad flame spreader, dirty flame spreader, more bad burners), the flame safety sensor does not detect flame (dirty or bad flame spreader, bad flame sensor, broken wire, bad control), or the room air blower does not energize (bad fan motor, bad control).
12/3/2016 2:00:27 AM • Mr. Heater... • Answered on Dec 03, 2016
OF COARSE I DIDN'T LOOK AT THE MODEL #, BUT IT'S A CEILING MOUNT MODEL, AND I'M GUESSING AROUND 30,000 BTU. IT STARTS AND RUNS FINE BUT THE CIRCULATION FAN NEVER COME ON AND THEN THE BURNER SHUTS DOWN
If the fan does not run that causes the unit to over heat that in turn shuts every thing down.Check and see if the motor is not burnt out.
12/16/2015 2:10:57 AM • Mr. Heater... • Answered on Dec 16, 2015
The led light is flashing 2 flash's saying system is in lockout, failed to detect flame, how do i fix this
The infrared heat/light sensor is either faulty or covered up (soot?)
9/7/2015 12:33:16 AM • Mr. Heater... • Answered on Sep 07, 2015
How do I access the igniter on a big max heater
Take side cover off and you will see a little and your igniter should be in there
3/28/2015 3:17:59 PM • Mr. Heater... • Answered on Mar 28, 2015
Maxx heater lights all burners for aprox 20 sec blower fan starts flame goes out flame lights again for 20 sec never blows much heat ?
sounds like its not getting gas fast enough to keep burning,that happen to me and the gas line was to long of a run for enough gas keep coming. so I up the pipe runs real good the flame keeps burning, so you know you can only go 25 ft in half inch pipe then u lose your flame
11/20/2014 1:55:59 AM • Mr. Heater... • Answered on Nov 20, 2014
0answers
2answers
Lennox hotshot garage heater, ignites
Look for a flame sensor located in the flame of one of the burners. It will look like a small rod or probe and will have only 1 wire going to it from circuit board. Polish it with a scrub pad or stiff wire brush. Check the wire for a good connection as well as any ground wires off of the circuit board.
7/3/2014 7:42:46 AM • Mr. Heater... • Answered on Jul 03, 2014
Im not getting any heat. Fan kicks on but no burners. 4 flashing lights
check your limit switch
7/1/2014 6:30:42 PM • Mr. Heater... • Answered on Jul 01, 2014
Circuit board blinks 4 times
I am only guessing since you have not given very much information. I would check to see if you have the power phased right. Some boards are polarity sensitive. Which means that the common should not have voltage to ground. Check and make sure L1 has 120 volts to ground and common. and that you have 0 volts from common to ground..
1/31/2014 3:35:53 AM • Mr. Heater... • Answered on Jan 31, 2014
Mr. Heater Natural Gas Garage Heater - 45,000 BTU Logo
88 questions posted
Top Mr. Heater Heating & Cooling Experts
Paul Carew
Jay Finke
Jay Finke
Are you a Mr. Heater Heating and Cooling Expert? Answer questions, earn points and help others
View Most Popular
  • Mr. Heater Heating & Cooling
Most Popular Question
im not getting any heat fan kicks but
  • Heating & Cooling
