20 Most Recent
Galileo New Age 800x80 Telescope Questions & Answers
I have a scope Galileo
It's not worth buying all those accessories for that 80mm scope. They would cost several times MORE than what you paid for it.
Read this:
http://www.texasastro.org/telescope.php
and this
http://www.texasastro.org/mounts.php
and also read my TIP about equatorial mounts on my profile page.
Dont know how to put the eye pieces on the
Eyepieces ALWAYS go into the focuser. Put the eyepiece with the largest number written on it into the telescope. Take it outside during the day time and practice focusing on a distant object.
The moon should be your first target at night. Read my TIPS on my profile page.
Need a manuelrroz
Contact Galileo telescopes here:
http://www.galileosplace.com/contact-us.html
The manual will have assembly instructions. IT WILL NOT help you learn how to use the telescope to find objects in the night sky!
Read my tips on my profile page.
Galileo 800 By 80 instrution manuial
You need to contact Galileo directly:
Here:
The manual will just have assembly instructions, it will NOT help you find objects in the sky. Locate a local Astronomy club and the members will help you.
Time table
You posted this question (?) in the Telescope Topic.
I dont have a clue which end is suppose to be facing upward.
If you have a telescope with a MIRROR then the end with the focuser is pointed UP.
If you have a telescope with a lens in the front and and the focuser on the end, then the end with the lens is pointed up.
Read this and look at the pictures that show which end is UP:
2 reasons why astromers launch telescopes into space
To get beyond the atmospheric turbulence, and TWO to position the scope in deep space and in very cold conditions for infra-red telescope operation, and THREE to investigate certain solar system objects like comets, asteroids, and the sun.
I want to clean it all up befor I give it to a
Lens cleaning_
http://www.company7.com/library/clean.html
Eyepieces come3 in .965 and 1.25 inch sizes. Measure the hole.
These people sell eyepieces_
http://www.optcorp.com/category.aspx?uid=30-720
http://www.agenaastro.com/
About the Same Thing
You will not find a manual for that telescope. Look on the Bushnell manual web site and locate one similar to your telescope. They all assemble in a similar fashion.
http://www.opticsplanet.net/bushnell-warranty.html
How to focus in on an object
First use the eyepiece with the LARGEST number written on it. This is your lowest magnification.
Then center the object in the telescope eyepiece, and without moving the telescope CENTER the crosshairs or the red finder dot on the target.
I unable to view from my Calileo F1100 x 102 mm Catadioptirc
Since you can focus on trees during the daytime nothing is wrong with the telescope-- most objects in the sky are very tiny-- you must be pointed directly at them to see them. During the day line up the small finder telescope on top with the main telescope-- then use the small finder to point the larger "tube" directly at the object in the sky.
I see invested in my galileo
I am assuming that you mean that the image at your eyepiece is inverted (upside down). All telescopes show an inverted image. You can add an erecting prism before the eyepiece if you wish to use the scope terrestrially (for looking at things on earth).
