Hello there
Disconnect all power to the machine first!!
1 Locate the outer clamp band securing the seal to the door
rim on the washing machine and examine it carefully for holes or
tears. Many can be prised off with a flat-bladed screwdriver they have a
spring system holding them, but some have a tensioning arrangement
that has to be loosened.
2 After removing the
outer clamp band,
locate the inner one securing the seal to the drum and establish how
this is secured. It may be necessary to loosen a clip, or you may be
able to prise the band off with a flat-bladed screwdriver. Some are like
very large Jubilee clips that you have to undo usually from the top.
3 Once the clamp bands have been removed, use both hands to
pull the seal away from the inner drum rim. Some AEG machines have a
water spout holes that will have to be lined up. Others have a drain
holes.
4 Rubbing a drop of washing up liquid into the groove on the
AEG door seal/gasket that locates on the drum makes fitting the new seal easier.
5 Your new
AEG washing machine door seal
should be fitted by locating the drain holes at the bottom of the seal
first then push it on with both hands working opposite directions
towards the top. This is quite hard if you have never done it before.
6 Refit the inner band remembering this must be tensioned correctly for it to be water tight.
7 now fit the outer band and the test your AEG machine for any leaks,
I
