20 Most Recent
Whirlpool GH6177XPS Microwave Oven Questions & Answers
F7 ERROR CODE ON GH6177XPS
This is a known problem with this unit, and whirlpool has put out a Service Flash out on this. The reason this is happening is Electrical circuit interruption between the L1 and Neutral in the microwave invert circuit. This has to be addressed by a Tech.
DrakeTech
6/17/2014 12:59:59 AM •
Whirlpool...
Answered
on Jun 17, 2014
Grilling bulb out
hello chris microwave is an american model
I found the tube/bulb you looking for is like the picture and called quartz grill tube and can be replace by similar voltage 120 v
4/8/2014 8:58:58 PM •
Whirlpool...
Answered
on Apr 08, 2014
My whirlpool Gr2 microven Model
Sorry to read about your problem.
It seems your have a general failure in the power control or switch failure on the unit. if you unit has power, and things lite. it is more likely you have a control/switch problem,
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
dsddd
6/10/2013 8:57:37 AM •
Whirlpool...
Answered
on Jun 10, 2013
Error code F7
Hi drk2676,
This error code F7 means that you have a function key stuck on ERC. You can solve this issue by replacing control board (also called ERC or clock). You may contact Sears for the replacement part at 1-800-252-1698; M-F 6:30 AM-10:30 PM - Sat 7:00 AM-9:30 PM - Sun 7:30 AM-9:30 PM - All times Central.
Hope this helps.
Thank you for using FixYa.
6/8/2011 3:34:57 AM •
Whirlpool...
Answered
on Jun 08, 2011
Microwave does not shut off when door is opened.
It may be a bad door switch or mount, or maybe a relay on the control board is sticking.
First, see our
safety info here.
Then we have a
helpful file on diagnosing and replacing door switches here.
If that's not the issue,
we regularly repair control circuit boards for $39.95, or you can order a new one (part number 8205237) for $203.08
here.
8/19/2010 2:21:29 AM •
Whirlpool...
Answered
on Aug 19, 2010
Touchpad does not work
This is a common touchpad error which
we regularly repair for customers nationwide for $39.95 one year guarantee.
At
our Web site, we have a video
available showing how to remove a typical
over the range control panel assembly in under 5 minutes.Feel free to contact me directly (and please remind me of your
full model number from the tag on the unit) for more
information & help.
We're
William E. Miller, AS-EET
[email protected]
http://www.microwavedisplay.comMicrowave Oven Control Panel Repair Nationwide
4/28/2010 4:48:12 PM •
Whirlpool...
Answered
on Apr 28, 2010
Touch pad not responding
We regularly repair such control
units for
customers nationwide by mail for $39.95 postpaid in about a
week or so with a one-year guarantee.
At
information & help.
We're
[email protected]
11/25/2009 10:20:52 AM •
Whirlpool...
Answered
on Nov 25, 2009
Have GH6177XPS. Everything works normally. Have
It would be unusual for even a Chinese fan to have failed bushings in that short period.
If this unit has a conventional power supply for the magnetron, the noise might be caused by the magnetic field of a large power transformer.
These can have a strong stray field and can cause other sheet metal near them to vibrate.
It isn't dangerous, assuming you don't poke a finger inside, to remove the rear panel and inspect the innards while it is operating. Using something that isn't metal such as a plastic or bakelite spoon (even dampness in a wood utensil can conduct a painful shock), you might try damping the vibration with it.
If you can locate the source, you may be able to kill the resonance by applying a fairly large bead of pure silicone (nothing else) to the surface making the noise.
It it seems to be coming from the transformer itself, I would pull the plug, let the unit sit ignored for a couple of hours (there can be charged capacitors inside) then use a finger to press silicone into the transformer's laminations.
These were once soaked in epoxy in a vacuum container to **** all the air from between the laminations to prevent exactly this kind of 'rattle.'
They probably don't take the time for that any more.
4/1/2009 6:20:00 PM •
Whirlpool...
Answered
on Apr 01, 2009
Whirlpool GH6177XPS G2 Microwave
Your generator may be putting out a square wave instead of a true sinusoidal (sine) wave.
There is usually a circuit in the microwave which monitors the AC line for timing purposes, and a square wave may not be interpreted correctly.
I would consult the manual or contact the manufacturer or installer.
We're happy to help and we appreciate your thoughtful rating of our answer.
2/17/2008 4:42:28 PM •
Whirlpool...
Answered
on Feb 17, 2008
