20 Most Recent Whirlpool EL02CCXP 19" Cold Pals Compact Refrigerator w/ 1.8 Cu. Ft. Capacity, Manual Defrost & Reve... Questions & Answers
Your model appears to be quite simple electrically. It does not have a major circuit board it's very possible that the pressure switch, wire connection at the dispenser, hinge or the interlock freezer lightswitch is bad on your model. Do you have a multi-meter/OHM meter? John T. Appliance 911 Appliance 911 Sea Breeze
Here is a manual that is very close to your model http://appliance911seabreeze.com/KSBS20QEWH0%20_ED20DFXEB00_Serviice_Manual.pdf
Whirlpool... | Answered on May 21, 2014
Only way a condensor can go bad is if leaks refrigerant or a line gets kinked. If by chance it gets clogged it can be cleared with nitrogen, it all depends on hold much service the tech knows. hope this helps.
Whirlpool... | Answered on Aug 11, 2011
Tom, I would start with the overload and relay that is on the compressor, If it is white it's a good possibility that it has failed. The fact that both sides are not cooling leaves me to believe the compressor is not operating. Take the overload and relay off. If they are both contained in a white cover shake it. If it rattles, I believe that is your problem. Let me know what you find...Catriver.
Whirlpool... | Answered on Feb 10, 2009
they have to put defrost heaters someplace
Whirlpool... | Answered on Nov 26, 2019
Hi
I have problems with whirlpool refrigerant the compressor not working no any electric power came to it that for I checked all the ather thing it's ok and the out fan behind the compressor it usually working.
My question is what the main thing to make compressor not working in the same time fan are working.
Whirlpool... | Answered on Oct 17, 2019
In the freezer compartment there is a panel on the ceiling of the freezer, remove this with a small spatula, it snaps off, there is a dial that controls the airflow on the panel, inside this panel is the defrost control board, it does not use the old time defrost timer, it uses this part, its about $250
Cntrl-Elec Part Number: AP6023580 Made by: Genuine Whirlpool part OUR PRICE $259.12 REGULARLY YOU SAVE $260.53 $1.41
Whirlpool... | Answered on Oct 16, 2019
Most ice makers in domestic refrigerators make a noise when filling ice containers and when "dropping" ice cubes into ice container. If working OK then this is possibly the noise as described above.
Whirlpool... | Answered on Oct 03, 2019
Refrigerators Logo
8 questions posted
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Bruce Denton
Archie Ferrarini
Archie Ferrarini
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
  • Whirlpool Refrigerators
Most Popular Question
condenser
  • Refrigerators
