20 Most Recent
Bionaire BDQ25 Dehumidifier Questions & Answers
Drain hose is hooked up, however, "full" light is
The drain tube of hole inside the unit may be clogged. Unplug the unit and remove the water container. With a flashlight look up and into the unit to locate the tube or drain hole. Using a 12' long Zip Tie, carefully run the Zip Tie up into the tube or hole, as far as you can. Gently turn it and with draw the Zip Tie slowly. This should remove any clogs.
Hope this helps to solve your problem.
Bionaire BDQ25 QUIETech Dehumidifier, manual
all
Since Bioaire is stingy with their Owners Manuals, it's hard to tell you what the error code means. However, if you have misplaced your Owners Manual, you can contact the company"s Customer Service Dept for a replacement, as well as what the Error Code means and how to solve it. In CANADA and the USA Call 1-888-324-9907
Fan squeaking
Try spraying white lithium grease all around the shaded pole motor axle while the motor is running making sure to have it get into the bearings
10/16/2013 2:02:52 PM •
Bionaire...
Answered
on Oct 16, 2013
I have an ebac15 dehumidifier. When I moved it there was an oily liquid underneath. Why would this be?
There could be several reasons why you're finding an oily liquid underneath your Ebac15 dehumidifier:
Refrigerant Leak: If the dehumidifier is leaking refrigerant, it could result in an oily substance pooling underneath. Refrigerant leaks are often accompanied by an oily residue1\.
Compressor Issue: A malfunctioning compressor can cause refrigerant leaks and result in an oily substance accumulating underneath the dehumidifier.
Condenser Coil Leak: If the condenser coil is damaged or deteriorating, it may lead to refrigerant leaks and the presence of oil underneath the dehumidifier.
Internal Component Failure: Internal components such as seals or tubing may degrade over time, leading to leaks of refrigerant or oil.
Improper Handling During Transport: If the dehumidifier was tilted or handled roughly during transportation, it could have caused oil from the compressor or other internal components to leak.
Given the potential hazards associated with refrigerant leaks, it's advisable to discontinue the use of the dehumidifier and consult a professional technician for diagnosis and repair.
