20 Most Recent All-Pro Kerosene Garage Shop Heaters - All Pro PK115T Forced Air Kerosene Space Heater Questions & Answers
Fan motor cz220 garage heater replacement
the best place to look for replacement motors is at Johnstone Supply.
4/26/2023 3:24:34 PM • All-Pro Kerosene... • Answered on Apr 26, 2023
Toyotomi laser 73 no fuel to injector
it is not a CAR it is a space heater, must we guess it is Kerosene and sump means fuel tank? yes most fuel heaters on earth have ignition tests (sensors) so you to hot have huge fuel fire. , SAFETY FIRST>page 3 see it? so RTM https://toyotomiusa.com/wp-content/uploads/2021/09/Laser-73-and-73ATType-M.pdf
9/17/2022 2:03:33 PM • All-Pro Kerosene... • Answered on Sep 17, 2022
2answers
My heater keeps shutting down.
Here are a couple of tips that I wrote that tell you how to troubleshoot a Torpedo or Reddy heater...
Reddy Heater - Troubleshooting Torpedo Heaters
Torpedo Heater Pump Pressure Adjustment
heatman101
11/4/2021 6:28:49 PM • All-Pro Kerosene... • Answered on Nov 04, 2021
I have a feature Comforts Oil filled heater It
Yes it does have a reset and fortunately a simple fix How do I reset my comforts zone heater? To reset the heater, simply turn power off and unplug the heater for 10 minutes until it cools down and then you may plug the heater in and restart.
CZ448 Ceramic Heater Inst LR 111512 - Global Industrial
10/11/2021 11:52:46 PM • All-Pro Kerosene... • Answered on Oct 11, 2021
We replaced the motor on our dayton 100,000 btu
Might have a bad board or relay .
Check to see what turn the fan on because your fan should run when heater reaches a certain temperature.
4/20/2018 6:25:20 AM • All-Pro Kerosene... • Answered on Apr 20, 2018
I have a Remington 100 Heater. Was running fine
Similar heaters that use diesel have to routinely cope with the dye added to untaxed fuel, ditto similar heaters that use both fuels. Unless there was an excess of dye in the fuel you used the problem was probably a coincidence. Dirt can be a big problem due to corrosion forming in the fuel tank caused by a relatively large percentage of moisture naturally in the fuel and the formation of condensation. Fuel is generally filtered through a fine gauze when the tank is filled but there is little or no filtration preventing dirt already in the tank from being picked up and finding a way into the spray head which generally jams the spinner affecting the quality of the fuel spray. Cleaning the spinner and nozzle might work for a while but only a major clean out will restore reliability until the next time. It is also wise to check and adjust the pressure of the air pump.
2/18/2018 11:22:11 PM • All-Pro Kerosene... • Answered on Feb 18, 2018
2answers
My Champion heater is a
You can check the capicator. This is mounted next to fan motor.
There should be 2 wires going to it
5/19/2017 3:07:09 PM • All-Pro Kerosene... • Answered on May 19, 2017
Cant get my electric kerosene heater to light
Could the fuel be too old? I would recommend dumping the fuel in an outdoor firepit and burn it up. Use an inexpensive "Turkey Baster" to suck it out of the tank. Then put fresh kerosene in and try it. If you need further help, I’m available over the phone at https://www.6ya.com/expert/dan_77d17b8918f54455
4/2/2017 6:43:34 PM • All-Pro Kerosene... • Answered on Apr 02, 2017
2answers
I have a heat hog
Usually it is one of the hoses that goes to the burning unit. One hose supplies fuel the other I think is a air pump hose. If either one has a crack in it or is not connected tight, it will not provide the proper pressure for the igniter to work. Check both of the hoses and I bet you will find one of them that is bad. Replace them and it will work again. Mine has done this every year.
2/7/2016 11:27:45 PM • All-Pro Kerosene... • Answered on Feb 07, 2016
I have an all pro
heatman101
1/30/2016 9:04:04 PM • All-Pro Kerosene... • Answered on Jan 30, 2016
Hi i have a master
heatman101
10/10/2015 5:01:12 PM • All-Pro Kerosene... • Answered on Oct 10, 2015
What is a cad cell and what does it do
A cad cell is a photo-electric device that reads the UV rays given off by flame after it has ignited. If it does not 'see' the flame, due to a flame failure OR a cad cell failure, the control circuit is locked out. Make sure there is no carbon on the front (window)of the cell and make sure its adjustment is in perfect alignment to the flame.
2/19/2015 11:30:11 PM • All-Pro Kerosene... • Answered on Feb 19, 2015
My all-pro uk115t shuts off after a few seconds
This is normally due to either a clogged intake filter, or water in the fuel. To rinse the intake filter and the tank, put in a quart of fuel and shake, shake, shake to rinse crud off filter and dump out. Otherwise you'll have to disassemble to get to the filter. To remove water from fuel, dump it into a bucket. The water will coalesce in the bottom, then pour slowly back into the tank, leaving the 'bubble' of water in the bucket.
2/18/2015 11:48:12 PM • All-Pro Kerosene... • Answered on Feb 18, 2015
How do i bypass the themstat on a workhorse heater
As you should know thermostat is for safety and it is not good idea to by pass it ,not recommended
2/5/2015 2:55:50 AM • All-Pro Kerosene... • Answered on Feb 05, 2015
All-Pro Kerosene Garage Shop Heaters - All Pro PK115T Forced Air Kerosene Space Heater Logo
378 questions posted
Top All-Pro Heating & Cooling Experts
Paul Carew
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you an All-Pro Heating and Cooling Expert? Answer questions, earn points and help others
View Most Popular
  • All-Pro Heating & Cooling
Most Popular Question
remington 100 heater running fine
  • Heating & Cooling
