20 Most Recent Jenn-Air 30 in. JGD8430A Gas Cooktop Questions & Answers
The ignitor will not stop sparking.
Here is a tip that I wrote that will help figure out why the burner spark keeps on clicking...
Gas Range Repair Burners Keep on Clicking
http://www.fixya.com/support/r4033033-gas_range_repair_burners_keep_clicking
heatman101
8/18/2010 11:28:15 PM • Jenn-Air 30 in.... • Answered on Aug 18, 2010
Need to convert my osburn G2 stove to LP,
Ask your LP supplier to add a gas regulator to the line going to the stove and then you wouldn't have to do anything to the stove itself.
11/7/2009 1:23:59 PM • Jenn-Air 30 in.... • Answered on Nov 07, 2009
Recent install, using lp kit, in use it seems like
try to repalce the regulator.sometime the problem is not in unit? in regulator or if u have other regulator try to use then check it. if same thing again,call an expert tecnician to check the gas line & the unit.do not try to repair by it ur self ocz if hard & itr danger
7/4/2009 2:26:44 PM • Jenn-Air 30 in.... • Answered on Jul 04, 2009
JENN-AIR JGC8645ADS
Glad you found the problem.
Hope this advice helped.
5/24/2009 4:42:33 PM • Jenn-Air 30 in.... • Answered on May 24, 2009
3answers
Jenn-Air JDG8430 Ignitor won't stop sparking after burner ignites
Test the ignitor first, if the ignitor does not spark should be the ignitor itself.
10/20/2008 8:58:09 AM • Jenn-Air 30 in.... • Answered on Oct 20, 2008
replace the igniter.
10/20/2008 8:30:40 AM • Jenn-Air 30 in.... • Answered on Oct 20, 2008
I need a manual for a Jenn-air cooktop PN 201595D
Jenn Air are high end and are Secretive with Service Manuals. You need a Service call and a whole load of money. It will be the controller or the board, or crack in the burner element. Even the controller switch is 150 bucks! https://www.google.com/search?q=Jenn-air+PN+201595D+manual https://www.appliancepartspros.com/search.aspx?model=c221%20pn%20201595e ..
12/23/2023 3:49:00 AM • Jenn-Air... • Answered on Dec 23, 2023
Jenn-Air C301 Cooktop. Wiring instructions for electric burner switch on a Jenn-Air model C301
Question edited for clarity, name of maker. Question moved to sub category. The service manual is here. You have to register. https://appliantology.org/files/file/4442-jenn-air-c301-cooktop-service-manual/ Other diagrams and text articles https://www.google.com/search?q=jenn-air+c301+wiring+diagram ..
9/27/2023 5:55:12 PM • Jenn-Air... • Answered on Sep 27, 2023
2answers
I have a Jenn-air electric ceramic cooktop. There's an issue with one of the surface control knobs. It now turns off in the "high" position instead of the "off" position. How do I fix this?
limited info generic answer check that control is mounted correctly test selector with a meter most likely its failing
7/24/2023 5:57:04 PM • Jenn-Air... • Answered on Jul 24, 2023
Jenn-Air Expressions Downdraft Gas Stovetop Model CVGX2423B - Unable to Get Nut Off Burner Base to Replace Igniters
It is possible to use WD-40 to help loosen the nuts, but it may not be enough on its own to remove them. Here are some steps you can try to remove the nuts:
  1. Turn off the gas supply to the stovetop and unplug the unit from the electrical outlet.
  2. Use a wrench that fits the nut snugly and try turning it counter-clockwise to loosen the nut.
  3. If the nut is stuck, try spraying a generous amount of WD-40 onto the threads of the nut and let it sit for a few minutes.
  4. After the WD-40 has had a chance to penetrate the threads, try turning the nut again with the wrench.
  5. If the nut still won't budge, try gently tapping the wrench handle with a hammer to help loosen the nut.
  6. If all else fails, you may need to call a professional technician to remove the nuts safely.
It's important to note that improper removal of the nuts could cause damage to the stovetop or cause a gas leak, which could be dangerous. If you are unsure about how to proceed, it's best to call a qualified technician to help you.
4/23/2023 7:31:56 AM • Jenn-Air... • Answered on Apr 23, 2023
Is there anyway to remove the Downdraft Filter Tray for a Jenn-Air Gas Cooktop
where there is a will there is a way --correct you will break it - it is tacked to frame ---to remove it you need to tear apart the unit ---purchase a claw style part retrieval tool $4 at harbor freight -$11 home depot---lowes etc
4/25/2022 3:06:28 PM • Jenn-Air... • Answered on Apr 25, 2022
The burner-on indicator light is flashing for the right front burner on my Jenn-Air 9530ADW electric cooktop and the burner won't come on.
The flashing pilot light probably means the element has failed and it is in need of a repair.
7/11/2021 7:37:00 PM • Jenn-Air... • Answered on Jul 11, 2021
3answers
I need Part No. PHS120A-3377
Hello & Welcome to FixYa
Part PHS120A-3377 has been replaced by part# 74009254 which you can buy from either this link or from sears. Please get back to me if you have any other questions.
Kevin
4/28/2020 2:08:34 PM • Jenn-Air... • Answered on Apr 28, 2020
I have a electric cooktop,when I turn on a burner the one next to it turns on as well .If I take the other cartridge and swap it out, it does the exact same thing.It is brand new unit right out of the
sounds like you may have a bad harness or bad infinite switch, you can test it with a multi meter. Surface burners are typically either a coil type, solid type or a ribbon coil as used in smooth top ranges. All of these consist of a heating wire that uses electric current to produce heat. Coil type elements can be checked for continuity by removing them from the terminal block and testing them with a multi-meter.You should also inspect the terminal ends for signs of heat damage or corrosion, and if present, you should replace the terminal block or receptacle at the same time. You will need to remove power from the range to change the terminal block. Solid elements and smooth top elements require raising or removing the main top to gain access. You will need to remove power from the range before lifting the main top. Continuity can then be checked with a multi-meter, once you have removed the wires from the element terminals. On modern electronic control ranges,the oven temperature sensor is the part thatregulates the oven temperature. If it is not working properly it could be the reason why the range or oven won't start. This part can be found inside the oven on the rear wall near the top. Most modern ovens will display a fault code if the oven sensor is at fault. If you think the sensor may be the issue you can check the resistance with a multi-meterbut will need to know the correctresistance of the sensor at room temperature. Remove power from the appliance before performing this test. The infinite switch on the control panel controls the power to each surface element. If you have no heat at an element and the element and terminal block check ok, then you may have a defective infinite switch. Disconnect power to the range and remove the console back panel. Locate the switch and check foroverheated wires or faulty terminals first.Test the switch's contacts for continuity with a multi-meter. If defective, replace the switch.
  1. If the infinite switch does not appear to be defective, then you should check for proper voltage to the switch. This is a live high voltage test and should only be performed by qualified persons.(Locate the suspect switch for testing. Label all wires and terminals before disconnecting. A close up digital photo may be helpful.
  1. On the burner control switch the terminal labeled "P" leads to the burner indicator light. The terminals labeled "H1" and "H2" lead to the burner element and the terminals labeled "L1" and "L2" (sometimes "N1" and "N2") are the power supply wires.
  1. Set yourmultimeterto ohms setting x1. Turn the burner control to the highest temperature setting. Place one probe on pin "L1" and the second probe on pin "H1". The resistance measurement should be very low, zero to twenty ohms. If the test shows high or infinite resistance, the burner switch is defective.
  1. Repeat the step above for the terminals "L2" and "H2".
  1. If the control passes that test, turn the temperature setting to about the middle of the range and repeat the previous two steps. This will test for an intermittent problem with the switch. If the test does not show continuity with very low resistance, the switch should be replaced.
  1. With the switch turned to the "Off" position, the resistance on each of the pairs of terminals tested above should now show no continuity or a reading of infinite resistance.
  1. A test for continuity between "P" and "L1" when the burner control switch is on should show continuity. The light should be on whenever the control is turned on. If your test shows continuity, but the light does not operate, it is likely the bulb has failed.
If the burner switch shows high or infinite resistance, the switch is not passing along current to the burner and so the switch should be replaced. ) Most modern ovens usean electronic control board to control the oven functions. These models will use the control board to operate the oven safety valve on a gas range or oven, and the bake and broil elements on an electric range or oven. If there is no power to the igniter circuit, or the element circuits, then you should check the control board to verify that there is power at the appropriate output relay. These are live voltage checks and should be performed by qualified persons only. If there is no output voltage then the control should be replaced. The oven burner igniter commonly known as the hot surface igniter is used in modern gas oven burners to open the gas valve and to ignite the gas. As the igniter draws electric current it will heat to a high temperature and glow, as well as cause the bi-metal in the oven safety valve to warp and open the valve releasing the gas to be ignited. This sequence normally takes about a minute. Igniters come in both flat and round styles and are very fragile. If the burner does not light then you should check the igniter first. If the igniter does not glow at all, then check for power to the circuit. This is a live voltage check and should be performed by a qualified person. If power is present then the igniter may be open circuit and can be checked for continuity with a multi-meter.If the igniter is glowing, but the burner is not lighting, the igniter may be weak and still be at fault because it requires a certain amount of current draw to open the valve.This check requires the use of an amp meter and should be performed by a qualified person. If the igniter is defective then it must be replaced. http://www.partselect.com/Repair/Range-Stove-Oven/Will-Not-Start/ https://www.repairclinic.com/RepairHelp/How-To-Fix-A-Range-Stove-Oven/18---/Oven-won-t-turn-on- element burner testing range element-short.2-undefined-undefined-0.gif infinite switchs stove-undefined-undefined-2.jpg infinte switch_noheat_03-undefined-undefined-5.jpg oven harness ge-switch-ignition-harness_l-undefined-undefined-9.jpg if the harness is damaged it may effect any of the others down the line as well causing the burners to act up as they are wired in series
3/17/2020 4:29:34 AM • Jenn-Air... • Answered on Mar 17, 2020
MY JENN-AIR when it is turned on with one burner some times the other igniters start sparking on other burners
If the burner switch shows high or infinite resistance, the switch is not passing along current to the burner and so the switch should be replaced. ) Most modern ovens usean electronic control board to control the oven functions. These models will use the control board to operate the oven safety valve on a gas range or oven, and the bake and broil elements on an electric range or oven. If there is no power to the igniter circuit, or the element circuits, then you should check the control board to verify that there is power at the appropriate output relay. These are live voltage checks and should be performed by qualified persons only. If there is no output voltage then the control should be replaced. igniter spark clean ur ignitor-undefined-undefined-0.jpg ignitor spark ignitor-undefined-undefined-2.jpg ignitor gas spark ignitor-undefined-undefined-5.jpg ignitor damagedsparkignitor-undefined-undefined-9.jpg infinte switch_noheat_03-undefined-undefined-14.jpg infinite switchs stove-undefined-undefined-20.jpg
3/17/2020 3:55:50 AM • Jenn-Air... • Answered on Mar 17, 2020
My question is on Jenn-Air STOVE JGS8860BDP18, I need to replace the 4 burner Spark Module. Where is it located and how do I get to it??
It could be under the top or in the back. Remove the top and look for it there first. Part 18 is what your looking for, good luck. jenn-air dia-xbl2pe5dto2xvxzh3opkeyoa-5-0.gif
10/11/2018 3:16:42 PM • Jenn-Air... • Answered on Oct 11, 2018
Jenn-Air 30 in. JGD8430A Gas Cooktop Logo
12 questions posted
Top Jenn-Air Cooktops Experts
Paul Carew
Paul Bade
Are you a Jenn-Air Cooktop Expert? Answer questions, earn points and help others
View Most Popular
Jenn-Air Cooktops
  • Jenn-Air Cooktops
Most Popular Question
  • Cooktops
