20 Most Recent
Jenn-Air 30 in.JGD8430ADS Gas Cooktop Questions & Answers
Spark module will not stop after lighting burner
The module might not sense the flame: check electrical connections: wire (and its contacts0 and conections by fryer chasis; to be sure please bond with 18AWG wire pilot burner with spark module green wire.
MarKor
I get spark on all 4 burners but one will not
Sorry to read about your problem, I hope this helps you out.
you have a defective gas valve, or a clog of grease in the gas piping...try taking a needle and poke the little gas holes to clean in the area of the spark unit
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
All the burners are clicking
Hi there.I think what you have done is you have gotten water in & its just shorting out & causeing them to click.this should go away once it drys out.Meanwhile leave it unplugged.plug it back in every so many hour & see if it's stopped.
I have a Jenn-air gas range that is suddenly
Is the exhaust clear all the way out? Unplug the range and see if the problem goes away, if so you may have a control problem that is keeping the fan operating at a very low speed.
Good Luck,
Gilshultz
Romvoing the top of my Whirlpool Cooktop
well usually you have to remove the knobs. thentake all of the caps off of the burners. sometimes there are scres that hold the burner caps on. make sure you turn the power off. Then after you have done this the glass should come right off. If not there may be screws under the cooktop. Do these first steps and let me know how it goes.
