20 Most Recent
Frigidaire GLWS1339C 3.0 Cu. Ft. Top Loading Washer Questions & Answers
How do I put my washer belt back on
Hi dvasicke326 - Honestly, due to safety and liability reasons please contact a professional to move forward accurately. Usually this type of information is not release to someone who is not a technician and it is very rare to find enough information to do it yourself. In most cases this information can be found on the internet; however it is not provided directly from the manufacturer.
Glws1339cs1, started making noise like a belt was slipping during the spin cycle
Hello Bill Johnson - Is the washer draining or spinning? Could it possibly be a humming noise? If it is not doing either or and making a humming noise then it could possibly have a restriction in the drain line. Or either the belt is loose and will have to be put around the transmission and then spin it on to the motor or there is an issue with the lower/upper bearing. I would suggest contacting a professional to move forward accurately to properly diagnose/repair the washer.
My washer won't spin.
Normal
0
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";}
Problems with a washing machine not spinning or not draining are often inter
related..
If you are having a problem with your top load washer then check out this
tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout
this tip...
Front Load Washing machine not draining and or not spinning
heatman101
My frigidaire washing machine will not agate on
If your washer doesn't agitate, check
these:
Lid switch
If the lid
switch is defective, the washing machine may not agitate or function at all.
The switch is inside the washing machine main housing near the door frame.
Often you have to raise or open the top or front of the washing machine to get
to the switch. If it's defective, you need to replace it.
Motor coupler
Many washers
produced by Whirlpool® use a small, relatively inexpensive motor coupling. It's
plastic and rubber and is mounted to the shaft of the motor on one side, and to
the transmission on the other. Over time, the coupler wears out and fails. If
this happens, you need to completely replace it.
Belts
Many washing
machines have one or two belts. If a belt is broken or badly worn, you need to
replace it with a genuine belt from the manufacturer. (Some washing machine
belts are designed with special characteristics not found in automotive belts.)
Clutch
If your washer
was made by GE®, it may use a clutch for agitating the clothes. As the clutch
wears out, it may prevent the washer from agitating well or at all. If the
clutch is worn, you need to replace it. For this job, you probably want to hire
a qualified appliance repair technician.
Drive motor
Many washer
brands use a reversing motor. For agitation the motor runs in one direction,
for spinning and draining, the other. It's possible for a motor to burn out in
one direction and continue to operate in the other. If this happens, you need
to replace the entire motor.
Drive pulleys
The motor or
transmission drive pulley may be worn and unable to turn the drive belt. If so,
replace the pulley.
Transmission
The
transmission could have either of these problems:
Older washers
produced by Whirlpool® have a transmission with an electro-mechanical shifter.
If the shifter becomes even partially defective, the unit may not agitate
properly or at all.
The
transmission may have a worn or broken gear, or some other internal problem.
If you suspect
a transmission problem, you may have to call a qualified appliance repair
technician to repair it.
Agitator
The inside of
the agitator--where the transmission shaft attaches--can become worn, and strip
out the spline that allows the agitator to properly grip the shaft. Then the
transmission shaft rotates back and forth as it should, but the agitator
doesn't move properly. If this happens, you may need to replace the agitator
and/or the transmission spline.
if not familiar with doing this then you can
get it checked by local appliance repair technician familiar with this brand
and model.
You
can get required parts from www.repairclinic.com
This will help. Thanks please
keep updated.please do rate the solution positively .thank you for
using fixya
5 yr old washer is leaking
Ellbee, remove the two screws at the bottom of the front panel and lift it towards you. Two clips on the top that hold it will release. You can now get a good look at the pump. Catriver..post back.
My Frigidaire Affinity washer makes a loud buzzing sound when you push the start button and will not start, what can I do
Good Morning Anonymous, this is Z. I am happy to assist you!
I understand that your door indicates it is open and your dryer will not operate. Let's attempt resetting your dryer by either unplugging it or flipping the household circuit breaker off. It is good to wait approximately ten minutes and turn on your dryer. Select a normal cycle and verify if your dryer will start. If your dryer will not operate then it possibly have a faulty door lock assembly or a communication problem with the control board. At this point, it would be advisable to contact an experienced appliance repair tech to assist further.
What's stopping my dryer from running continuously
Please power cycle your dryer and attempt to run it again. If this fails, please ensure that your clothes are evenly distributed so that they weight of the clothes doesn't cause the dryer to be shutdown. Just to double check, please ensure that you've cleaned the lint track of your dryer. Lastly, you can use an power outlet extender to help switch the power outlet that you're using to run your dryer as there might be something wrong with your current one.
Thank you.
My Frigidaire dryer won't run longer than 5 secs what's wrong how can I fix
There could be several issues that could cause your Frigidaire dryer to stop running after just a few seconds. Here are a few potential problems to consider:
- Thermal fuse: The thermal fuse is a safety device that shuts off the dryer if it overheats. If the fuse has blown, the dryer will not run.
- Clogged dryer vent: If the dryer vent is clogged, it can cause the dryer to overheat, which could trip the thermal fuse.
- Faulty cycling thermostat: The cycling thermostat regulates the dryer's temperature. If it's faulty, the dryer may not run for more than a few seconds.
- Faulty start switch: If the start switch is faulty, it could prevent the dryer from running.
- Faulty door switch: The door switch prevents the dryer from running when the door is open. If the switch is faulty, the dryer may not run.
To fix the problem, you'll need to diagnose which of these issues is causing the problem and then replace the faulty part. I recommend having a mechanic diagnose and fix the problem for you.
WHAT IS E11 ERROR CODE IN MICROWAVE FRIGIDAIRE
The E11 error code indicates a problem with the gas sensor DE32-60011A and or the wire harness DE39-40678D. Unfortunately the manufacturer has discontinued the sensor. You may want to try contacting local parts dealers, one of them might still have it in stock. Enter your part number in a search engine, a smaller company might have it or try eBay, Amazon or similar sites . Search by using the manufacturers part number. Try a used appliance store, sometimes they have the same model or a usable part for your machine.
