20 Most Recent
Frigidaire 24 in. PLD3465REC Stainless Steel Built-in Dishwasher Questions & Answers
Error Message 'Er' on frigidaire dishwasher
I had the same problem. I pressed the "Start Cancel" button, kept it down, then pressed "Rinse Only" button. The display then went clear. I pressed "Start Cancel" again, then "83" showed up on the display. I let it run its cycle, then it corrected itself. A little scary, but it worked. This answer board is great!
FGHD2433KF1 err eu
Good Afternoon Stacy,
I see that you are having trouble with your Frigidaire dishwasher, model# FGHD2433KF1, showing an error EU. I also see that you have had a technician out who stated that there was no vent inside the unit. I would start by contacting the manufacturer, to see if you are in warranty, and if not, if there is any assistance they can provide to you. Hope this is helpful.
-Best Regards-
WP
Error code ER then UO any ideas?
So far so good. I fixed mine by removing the vent and even though it says no repairable parts I disassembled it then removed the rubber gasket and cleaned it with a brush under hot water. I then cleaned the plastic ring it seals against. Next I removed the spring and stretched it to make it about a quarter inch longer and then reinstalled the spring then the rubber gasket and then closed up the unit. So far it is working fine. I suspect the real problem is that there is a tiny sensor that needs to be covered when the vent is closed. If this is not covered the uo error code is generated.
My frigidaire professional series aquasurge won't start
Good Afternoon Friend,
I understand your Frigidaire dishwasher, model# PLD3465REC, will not start. I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 20-30 minutes. Restore power and start any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
What does a co code on a frigidaire professional series dishwasher mean
Good Morning Friend,
I understand that you are receiving a CO code on your Frigidaire Professional Series dishwasher, model# PLD3465REC. C0 means that there is some type of communication error. I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 20-30 minutes. Restore power and run any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your washer status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Frigidaire 24 in. FDB4315LFC3 STAINLESS STEEL ERROR CODE UO
Hi Mark, thank you for your post!
Error code UO commonly means that the vent is in an open position. While your Frigidaire dishwasher is in wash cycle, the main control board is not receiving signal from the vent assembly.
Before reaching out to a professional, let's try resetting your dishwasher. This can be done by flipping the household circuit breaker off. It is important to wait approximately ten minutes and then turn your dishwasher on. This often clears most false-error codes. If resetting the power does not correct the issue, a professional will need to check the wiring between the vent assembly and main control board.
Best of luck!
I need to buy, a circulation motor and how can i
Hello Orland, I am happy to
assist you. I understand you are seeking information on where to purchase a
particular part. Most parts can be purchased directly from the manufacturer or
through a parts distributor in your area (part numbers may vary based on
distributor).
May I please have the model
number? You can typically locate the serial tag on the right side as you open
the door. With this information I can better assist you in providing you the
correct part number on the circulation motor for your dishwasher.
Thank you and I look forward to
your response.
Frigidaire dishwasher won't spray
Hello - Are you referring to the spray arms will not rotate? If so, do you noticed if the spray arm is cracked or broken? Will it rotate slowly? If so, you might have to remove and replace the spray arm assemblies. I will suggest verifying that there is enough water pressure coming into the unit. If any proves to be ineffective, it could possibly have a communication problem coming from the main control board or wiring connections to the dispenser, I would suggest contacting a professional technician to diagnose the unit accurately.
