20 Most Recent
Nikon Coolpix 4300 Digital Camera Questions & Answers
The battery of my nikon coolpix 4300 is not working it is a new battery, but whenever i put it to charge it charges but the camera does not turn on (sorry if the question is confusing)
It sounds like there may be a problem with your Nikon Coolpix 4300 camera that is preventing it from turning on, even when you have a charged battery installed. Here are a few things you could try to troubleshoot the issue:
- Check the battery contacts: Make sure the battery contacts on both the battery and inside the camera are clean and free of debris. If there is any dirt or corrosion on the contacts, use a clean, dry cloth to gently clean them.
- Try a different power source: If you're charging the battery using a wall outlet, try using a different outlet or a different charger. If you're charging the battery using a USB cable, try using a different cable or a different USB port.
- Reset the camera: Sometimes, resetting the camera to its default settings can help resolve software-related issues. Check your camera's user manual for instructions on how to perform a reset.
- Contact Nikon customer support: If none of these steps resolve the issue, it may be a problem with the camera itself. Contact Nikon customer support or take the camera to a professional repair service for further assistance.
I hope this helps!
HOW DO I TURN FLASH OFF WHEN I DON'T WANT IT?
You can turn the flask off by pressing the flash mode button, it looks like this:
You will see when the flash is off when an image is displayed on your screen which looks like this:
Thank you for using FixYa! Have a nice day and please remember to rate this solution.
Warm regards,
BearWeb
Trying to transfer photos from
Try NOT connecting your camera to your computer.
The best way to transfer pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa.
Organize edit and share your photos
Write protected memory card
SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
There are white lines in monitor of my nikon s4300...help??
I'm afraid only a technician can repair this. Perhaps some parts must be replaced.
If the camera still makes good pictures, perhaps you better learn to live with the lines. Check is the white lines appear on an image you view on your computer. If so, the sensor or processor is damaged. Then you better start looking for a new camera, because that will be cheaper than to repair you S4300
Memory full
what kinda memory card have you got in your cam?
