20 Most Recent Frigidaire 14.1 cu. ft. Upright Freezer (FFU14K0DW) Questions & Answers
It can be normal. Remember, the way a refrigerator works is by removing heat from somewhere you don't want it and placing it in a neutral location.
Frigidaire 14.1... | Answered on Jan 14, 2018
Sounds like a defrost problem to me.
Frigidaire 14.1... | Answered on Aug 03, 2017
If the sides are hot, look at the defrost timer. Sounds like it has stopped running with the defrost elements on. The compressor has a safety switch on it that opens either if the compressor gets too hot or if it pulls too much current when starting. If your power flickered a lot before coming back on, that triggered the safety switch. Now that it's running normally, I wouldn't worry. The defrost timer is your problem now.
Frigidaire 14.1... | Answered on Jul 10, 2016
opening burned out compressor.
Frigidaire 14.1... | Answered on Jun 12, 2016
There are some products that you can put on rust that cause it to harden and stop if from spreading, You would then have to repaint the door.
Frigidaire 14.1... | Answered on May 20, 2016
Hello Linda, thank you for your post!
I understand that your Frigidaire freezer is not freezing properly. This could be an issue with your sealed system (which is compressor, condenser, drier, or tubing) or your control panel. The recommended temperature setting for your freezer is 0°F. It is also possible that this could be a miscommunication within the freezer and I would suggest performing a reset. You can perform a reset by disconnecting the power cord for at least ten minutes. If the reset does not help resolve your problem you need to contact a professional technician for proper diagnosis and repair. -Matt
Frigidaire 14.1... | Answered on Jan 18, 2016
Check the freezer back wall for snow or frost.If it's there you have a defrost problem.
Frigidaire 14.1... | Answered on Dec 02, 2015
watch this video I made. this is subzero with low level of freon (almost out). same situation on all refrigerators and freezers. you can see ice at the begging of evaporator. if there would be a little more freon evaporator might of frost up at the top might frost half of evap other half would be not even cold.
Frigidaire 14.1... | Answered on Nov 21, 2015
E9 is a defective Temperature Control
  • You will need to replace Part # 297216004 It should be mounted on the evaporator behind the panel in the inside of the freezer.
  • I am including a picture and a link, it should be #21 on the diagram.
  • You have to unscrew the Knob and the 3 screws holding the temperature control Cover and the one holding the probe/sensor (#24 on diagram)
Best of Luck,
JP
http www searspartsdirect com model part FFU14K0DW0 1428 0142000 R0405108...
Frigidaire 14.1... | Answered on Jul 08, 2015
Good Afternoon friend, thank you for your post!
I see that your Frigidaire freezer is making noise and you have recently defrosted it, but your freezer is still making the noise. Your freezer will make certain noises which are normal operating noises for the freezer.
The compressor is a high efficiency so you may hear it during start up and while running. Additionally, refrigerant circulating through your freezer can make a tapping sound or even a gurgling noise. I hope this has been helpful. -Matt
Frigidaire 14.1... | Answered on Oct 02, 2014
That'll be the door sealing itself. If it continues longer than a minute, then something might be wrong
Frigidaire 14.1... | Answered on Sep 30, 2014
Hello friend, thank you for your post!
I see that your door ajar alarm is going off when the door is closed to your Frigidaire freezer. It sounds like a possible issue with the control panel or switch. Let's perform a reset to your appliance to see if that will correct the issue. You can do that by disconnecting power from the appliance for roughly ten minutes. I hope this helps. -Matt
Frigidaire 14.1... | Answered on Sep 25, 2014
Hello friend, thanks for your inquiry!
I understand that the top of your Frigidaire freezer is not cold but the lower half is. I would recommend to perform a defrost on your freezer, I understand that it is a frost free freezer but it could be that maybe something has caused it to freezer over. You can perform a manual defrost by unplugging your appliance for four to six hours. If that is unsuccessful and you are still not getting cooler temperature up top I would seek assistance from a professional to come out and diagnose your appliance. -Matt
Frigidaire 14.1... | Answered on Aug 19, 2014
the sides is were the condenser is it is called a hot wall condenser try to keep things from the sides so it can run more efficeiant
Frigidaire 14.1... | Answered on Jul 27, 2014
Good Morning Friend, thank you for allowing me to assist you!
Did your freezer previously experience a power loss? If the temperature of food rises to an unsafe level, the buzzer will sound and the red light, if equipped, will also glow. First, deactivate the alarm to your freezer by unplugging it or flipping the household circuit breaker. It is good to wait approximately ten minutes and then turn on your freezer. After deactivating the alarm and your freezer has run approximately four hours, the red light/alarm should go off on its own. If the red light/alarm continues to stay on, your freezer may possibly have a communication problem with the control board, temperature control or a wiring harness. If this is the case, I would recommend connecting with an experienced technician to determine the underlying cause. - Z
Frigidaire 14.1... | Answered on Jul 22, 2014
bad thermostat maybe
Frigidaire 14.1... | Answered on Jul 18, 2014
Frigidaire 14.1 cu. ft. Upright Freezer (FFU14K0DW) Logo
199 questions posted
Top Frigidaire Freezers Experts
John Tripp
John Tripp
Dennis Boxerman
Bruce Denton
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
View Most Popular
Frigidaire Freezers
  • Frigidaire Freezers
Most Popular Question
textured door sweats humid days place
  • Freezers
