Thank you for your post, Andrea!
You can hold down the water dispenser because that would prime your water line inside your Frigidaire refrigerator. If that is unsuccessful I would verify to make sure the water supply is correctly installed and turned on. Also verify that your supply line is not kinked that could cause the water to not dispense.
If you have verified all that information is correct then I would check your water filter. Assure it is installed properly and not clogged or restricted. Once you have completed all those steps if you continue to not receive water I would suggest having a professional come out to the home for proper diagnose and repair of your refrigerator. -Matt
Error code 4 usually means that there is a communication failure with the main control board and damper. Base on the intensity of the issue; contact a professional technician to diagnose the unit to assist with the repair.
Here is a tip that I wrote about refrigerators and the fan noise that they develop sometimes...
Refrigerator Fan Noise
heatman101
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.If your refrigerator is running but warm, then...Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...Refrigerator Condenser Coil Cleaning Refrigerator RepairRefrigerator Troubleshooting Refrigerator CompressorRefrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Coldheatman101
34 questions posted
750 Questions
598 Questions
459 Questions
272 Questions
173 Questions
