20 Most Recent
Schaerer Opal Espresso Machine Questions & Answers
Water in the waste bin
Check the brewer for visible leaks in pipes etc.. Check the orange top and bottom piston o-rings for wear. Generally its the o-rings which need to be changed. Part no. 65190
Schaerer opal is noisy on startup.
Is it noisy when the pump runs on startup? If so then the pump is airlocked, run water through the wand to release this... Depending on model, you can do this by placing a cup under the wand and pressing the jug button or turning the knob on right side to the water symbol.
No power to my schemer opal
Don't forget the that there's an on/off switch on the left hand side of the machine as well as the button on the front. You'd be surprised how many people this catches out.
Opal telling me beans lid is not on when it is ?
hi
i work on schaerer machines. on the back of the lid there are two plastic spikes that make contact with in the machine, when you lift the lid it breaks contact so when you select your product you dont put your hand near the grinder. order a new lid or write back and ill tell you how to jam it open. If you want?
I have a schaerer opal coffee machine, when I
I have a schaerer opal coffee machine, when I switch main power machine on, the descaling indicator, cleaning/rinse indicator and stand-by mode indicator lamp remains lit, and a pump runs continuosly. the machine do not ready mode indicator. Yudi INDONESIA
Water low indicator comes on
Sounds like a dirty boiler probe.The probe has lime on it and should be cleaned.If attempting to clean make sure unit is unplugged and cool.
