20 Most Recent
Netopia (3347NWG-VGX) Wireless Router (3347NWGVGX) Questions & Answers
Getting PS3 NAT type 2 with Netopia router!
u should have dmz on router. but if not u can try your modem. that was my issue. i still use router for connection and stuff but i enables ip/dmz to pass through on my modem and it changed to type 2 more info email me at
[email protected] on add me i believe my ps3 thing is ADV_WARfighter
7/29/2013 2:39:19 AM •
Netopia...
Answered
on Jul 29, 2013
Firewall
First turn off the firewall and then install it.....Open Windows Firewall by clicking the Start button->click Control Panel->click Security->click Windows Firewall.Click Turn Windows Firewall on or off. Administrator permission required If you are prompted for an administrator password or confirmation, type the password or provide confirmation. Click Off (not recommended), and then click OK.**If you need any kind of technical assistance you can contact support cell at
http://www.vtechsquad.com/
4/4/2013 8:46:19 AM •
Netopia...
Answered
on Apr 04, 2013
How do I block Facebook
dannagare842, go to filehippo.com get free facebook block or do what I did and use same .com get spamfighter and put it in spam folder, it's blocked and free!Joe Don
5/25/2012 9:38:22 PM •
Netopia...
Answered
on May 25, 2012
Where can I find my wireless key?
Try to access your router's gui. To do this, you have to use your internet explorer.
1. Get your default gateway address first.
a. press the windows key + R
b. type cmd then press ok
c. on the black screen type ipconfig then press enter
d. look for the default gateway address
2. Type the default gateway address on the internet explorer address bar and you will be able to see your router's gui
3. Refer to the manual posted on the link below. Refer to Chapter 7 to get the WEP key of your router.
note: you need to connect wired to your router before anything else.
Netopia Wireless Router Manual
7/8/2011 6:28:38 PM •
Netopia...
Answered
on Jul 08, 2011
My wireless link led is
1.open the router
2. get a tester
3. remove the led bulb that is not working (because to led sometimes breaks because of to much blinking
4. test it if it work
5. or if busted replace it
6. the important thing is its working
7.if you cant open it try bringing it in a computer shop
3/16/2011 2:46:33 AM •
Netopia...
Answered
on Mar 16, 2011
Why is my router not broadcasting wireless signal?
Hi and welcome to FixYa!
Is the wireless working on wire? If it does then the transmitter of the router has reached it's break point. It does happen and it's a common problem. I used to have the same issue too and the solution was to replace the router itself.
Hope this helps and thank you for using FixYa! Happy New Year!
1/3/2011 7:04:26 PM •
Netopia...
Answered
on Jan 03, 2011
Forgot my password how do
Hi friend,
As you have mentioned that you have forgot the password for the router, so you can reset the router to factory settings by pressing the "RESET" button on the back of the router. It is a very samll button and you need a paper clip to press it.
What you need to do is, you need to take the paper clip, put it in a small hole on the back of the router and press and hold the button for atleast 30 seconds.
Once you release the button, the router will come back to its factory settings.
NOTE: If you will reset the router, all the settings on the router for Ethernet and the Wireless will be lost and the router needs to be reconfigured.
12/7/2010 1:44:51 PM •
Netopia...
Answered
on Dec 07, 2010
Tried 192.168.1.1 to get in
You do need to find the IP....
Using a Windows Computer.... Get to a C: Prompt...
"Start", "Run" ...in white space.... enter "cmd"
At the C: prompt..... Type "arp -a" and hit the enter key.
Above command will show all IP's on your network.
11/6/2010 12:18:17 AM •
Netopia...
Answered
on Nov 06, 2010
How to get nat type 2 on linksys router
Step 1:Connect Modem - Router - Computer (Wired)
Step 2:Open Router Setup by typing http://192.168.2.1 on the address bar of internet explorer
Step 3:On the Left click firewall
Step 4:Leave the Password blank and click submit
Step 5:Disable it and click apply changes
Step 6:Scan and connect in the Xbox/PS3/Wii
Step 7: Get the IP Address of the Xbox/PS3/Wii
Step 8:Open Router Setup in the Computer
Step 9:On the left under Firewall Click DMZ
Step 10:Enable the IP Address of the Xbox/PS3/Wii in it
Step 11:Click Apply Changes
Step 13:On the left Under Utilities click System settings
Step 14:Scroll down to the bottom
Step 15:Enable UPnP
Step 16:Click apply changes
Step 17:Test the connection ,Check the NAT
If working then let me know
Goto : my blog for more information about belkin routers (Page is still under construction )
If it is still not working
Open Router setup
At the middle Under internet settings check the WAN IP
IF it starts with 192.168. or 172.16 Then you will have to contact your internet service and ask them to bridge the modem
8/20/2010 10:51:55 PM •
Netopia...
Answered
on Aug 20, 2010
How do I get open nat settings for xbox live
You Will Have to Disable the Firewall In Your modem / Router
And IF it is a router then Open The Ports
• TCP 80
• UDP 88
• UDP 3074
• TCP 3074
• UDP 53
• TCP 53
And also make sure that UPnP is Enabled
8/20/2010 10:49:42 PM •
Netopia...
Answered
on Aug 20, 2010
It is saying my computer does not have wireless
You can purchase USB adapter for cheap, maybe 16 bucks and make your computer able to connect to your router wirelessly.
Good place to get one is www.newegg.com
here is the link:
http://www.newegg.com/Product/Product.aspx?Item=N82E16833340015&cm_re=usb_wireless_adapter-_-33-340-015-_-Product
8/10/2010 2:33:00 AM •
Netopia...
Answered
on Aug 10, 2010
My network settings don't match wireless router.
First Option :
Connect your computer directly thru Router LAN Port. now
If your Computer is configured thru Static IP address then change it get IP address thru DHCP. and Re start the computer. So it will get IP address from Router and you will be able to access Router Admin thru browser.
Second Option
You will have to reset router to factory defaults. To do that ; There will be Tiny Hole or Switch on Router Back side or front side.
Using strait Paper Clip wire ; Put in that wire in that hole and give very light pressure for 5 to 10 second. Make sure that router is Power ON.
So your router will be resetted to Factory default. Now reconfigure it
3/9/2010 2:49:04 PM •
Netopia...
Answered
on Mar 09, 2010
Modern Warfare 2 Open Up NAT
Have a look in the user control panel of the router.
It's probably at 192.168.1.1 or 192.168.1.254.
Admin username and password will be as default unless you changed them.
It's probably to do with your router firewall. Ensure that it's configured to allow traffic to and from your xbox.
3/5/2010 12:37:13 PM •
Netopia...
Answered
on Mar 05, 2010
The wireless light is not illuminated and i can't
This is a sign of an old router/modem. Also, try unplugging all of plugs that connect to the router/modem. Also, is this affecting you in connecting to the internet? if so, I recommend purchasing a new router/modem. They are very cheap now-a-days. :)
Matt P,
Computer/Gaming Relations Team.
1/23/2010 11:21:26 PM •
Netopia...
Answered
on Jan 23, 2010
