20 Most Recent
Vivitar ViviCam 4345 Digital Camera Questions & Answers
I was told that my pictures are lost in some
Take no more pics until you've recovered your photos, take the memory card out of the camera. This is to reduce the chance of you overwriting some of your "lost" photos. There are many good freeware photo recovery software options that may help you recover your photos.
This article reviews and outlines several of the better ones.
I've accidently deleted all
Take no more pics until you've recovered your photos, take the card out of the camera. This is to reduce the chance of you overwriting some of your "lost" photos. There are many good freeware photo recovery software options that may help you recover your photos.
This article reviews and outlines several of the better ones:
Hi, When the camera is turned on, the LCD diaplay
The display being blank can be due to failure of the LCD or the CCD which is the optical sensor of the camera. So to confirm check the older picture to be seen on the display. Confirm this by checking the card on your PC. If the images/picture is seen to be of good quality, then the LCD can be faulty, fault on the linking cable or the control board.since you are able to seen the ICONS the LCD is good , Now if the picture taken are seen well the CCD is also OK and the fault seems to be a digital logic gate failure as there is no switching of the circuit .
This might require a probe and it might be a relative issue in the motherboard circuit or the processsor. Remove battery , press down all buttons to drain off voltage and see if the camera resets.
Thank You for using fixya
I have photos in the camera memory (not on a
No, you need a USB cable to transfer the pictures. images on internal memory cannot be moved to a memory card, sorry.
Thomas Drayton
Owner, www Darntoothysam com Digital Camera Repair
Hi,I went from Windows XP to Vista.Can I still
Sure. The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries. And you won't have to update the card reader when you update your computer or get a new camera.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
Card locked
SD type cards have a little switch on the card that can write protect or "lock" it. Take the card out of the camera and check this switch. To unlock it, it should be moved towards the edge of the card which has the electrical contacts.
Trying to transfer pictures from
Consider NOT connecting the camera to the computer.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive. Or you can use any photo cataloging program.
After I transferred the pictures
Hi have you try to removed the mem card out off the camrea and look on the mem card for a small slide button and moved to the unlock position if not its could be the mem card its self or
the mem socket inside off the camera..
hope that will help you
regards Alan..
User instructions for vivitar 4345
You can download and print the instruction manual in PDF format by clicking this
link.
On the page which opens, click on the "
Download" button to download and save the manual.
Please note:
Adobe PDF Reader is required to view this manual.
Download the latest version of Adobe Reader.
Hope this solves your problem. Thanks for using
FixYa.
Lens error
This is probably THE most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
No audio
I don't know why there is no audio in Media player unless you somehow turned it off. You might go through the menus at the top of the screen to see if there is a setting for audio on/off. Also, you might try playing your movies in Quicktime (a free download from Apple).
