20 Most Recent Polaroid i832 Digital Camera Questions & Answers
Where can I get a cd for my polariod i832 digital
You don't need a driver. The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries. Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa. Organize edit and share your photos
11/20/2014 10:53:43 PM • Polaroid i832... • Answered on Nov 20, 2014
My software CD does not support Windows 7, where can I find suitable software in order to download my photo's
Did you try to contact Arcsoft already? They made the software, perhaps they have an update for windows 7 and 8? Or contact Polaroid?
1/13/2014 12:21:49 PM • Polaroid i832... • Answered on Jan 13, 2014
manual
CRACKED SCREEN
You cannot repair the broken LCD screen; the white you are seeing is the backlight for it. LCDs have extremely thin gold deposits along one edge that is contacted by a silicone rubber strip that has fine wires molded into it vertically and one edge is pressed against the LCD panel for contact. It is a fussy arrangement when new and it sure doesn't get any better when dropped.
I wouldn't delay too long looking for parts or repair; Polaroid filed for bankruptcy last week although I doubt if the parent had anything to do with the manufacture of your camera; as with many companies with limited manufacturing means, the camera was surely built by others.
6/20/2013 10:47:41 PM • Polaroid i832... • Answered on Jun 20, 2013
3answers
Polaroid t831 Digital Camera
You may refer to this digital camera picture recovery solution that helped me before. You may also take a look at this camera file recovery blog which contains information for how to recover deleted files from digital camera.
5/27/2013 9:29:03 AM • Polaroid i832... • Answered on May 27, 2013
4answers
Polaroid i830 driver
I need a solution, I don't have one
8/3/2012 12:43:55 AM • Polaroid i832... • Answered on Aug 03, 2012
My software had been corrupted for polaroid i836. how to get software.
You don't need any special software.The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
8/3/2012 12:43:05 AM • Polaroid i832... • Answered on Aug 03, 2012
My Polaroid i832 won't come on and the lens
I have a possible answer to your problem but FIXYA won't let me send it to you.
10/5/2011 9:30:14 PM • Polaroid i832... • Answered on Oct 05, 2011
0answers
I am trying to dowload
Having gone over a month without a response to my query, I assume my suggestion to use a card reader solved the problem.
9/15/2011 7:58:31 PM • Polaroid i832... • Answered on Sep 15, 2011
Does the camera take Lithium or Alkaline?
You can use any AA sized battery that you wish to use.
7/11/2011 2:26:23 PM • Polaroid i832... • Answered on Jul 11, 2011
I1246 Polaroid 12.0 need booklet how to use it.
Here is a tip that I wrote about how to find the manuals, drivers, downloads andsupport for Digital Cameras.
DigitalCamera Manuals, Drivers, Downloads, and Support How to easilydownload Pictures from Digital Camera
heatman101
5/19/2011 2:19:25 AM • Polaroid i832... • Answered on May 19, 2011
Don't have the cd
Having received no response in over a month to my query, I assume my suggestion to use a card reader solved the problem.
5/13/2011 5:19:13 PM • Polaroid i832... • Answered on May 13, 2011
My computer tells me that the camera driver on my
You could use your memory card reader instead of directly connecting the camera to computer. Usually you could find these in many of the laptops. if card reader is not a solution for you, try finding the driver through internet.
4/5/2011 11:45:47 AM • Polaroid i832... • Answered on Apr 05, 2011
Computer won't let me download pics
Try NOT connecting your camera to your computer.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
4/4/2011 4:53:50 PM • Polaroid i832... • Answered on Apr 04, 2011
New computer with windows 7, software that came
Having gone over four months without a response, I assume my suggestion to use a card reader solved the problem.
3/24/2011 6:34:37 PM • Polaroid i832... • Answered on Mar 24, 2011
The lens cover is not
this problem is caused because that the lens servo can`t move the unit of lens. this menssage mean that the sistem don't go out the lens.
You have to sincronise the mechanism of the lens, carefully disarm the unit and review that the gears are ok....
Thanks.
3/14/2011 10:55:29 AM • Polaroid i832... • Answered on Mar 14, 2011
My San Disk is full. I have saved the photos and
Go into the camera menu and find "format" and follow the on-screen instructions.
3/9/2011 8:58:27 PM • Polaroid i832... • Answered on Mar 09, 2011
How do you get rid of card locked message on Polaroid T830?
SD cards have a tiny slide tab on the edge of the card.
This is used to lock the card, so you can't alter the contents.
Slide the tab to unlock the card.
2/17/2011 11:54:03 PM • Polaroid i832... • Answered on Feb 17, 2011
Polaroid i832 Digital Camera Logo
75 questions posted
Top Polaroid Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Tom Shanks
Tom Shanks
Are you a Polaroid Camera Expert? Answer questions, earn points and help others
View Most Popular
I Polaroid
  • I Polaroid
Most Popular Question
polaroid t831 digital camera
  • Cameras
