20 Most Recent
Pentax *ist DL (W/18-55 LENS) Digital Camera Questions & Answers
I cannot take pictures while connected to computer with a usb cable
Is there anything to make you think you should be able to? I took a quick look at the manual and didn't find anything to imply that. Many cameras when connected to a computer serve only as a fancy card reader, allowing you to download pictures, and not as a camera that can take more pictures.
If you see anything in the manual, please point it out to me. In the meantime, what operating system are you running on your computer? Are you using any software on the computer for remote operation of the camera?
Hi, i have a pentax
Check your lens there is often a AF/MF auto/manual focus switch
Other than that it could be a problem with the camera take it to your dealer
LENSE
Make sure the aperture ring is set to the "A" position. If the lens doesn't have an auto aperture setting then I don't think the lens will work.
There is a setting called "Using Aperture Ring" that you can setup using the menu and configuration that can be set to "Permitted" that will allow you to take pictures even if the aperture ring is not set on "A", but not sure how well this work for you, but should allow the shutter to work.
Why isn't my K100D Flash not working?
please ensure that you've not used the camera for more than the advised amount of time by the manufacturer. Also, you can attempt to use the same brand/type of batteries as was including with your camera when you got it. Some manufacturers put internal fimware/software restrictions on their devices. For printers, this would be done for cartridges and in the case of your camera, it would be for batteries.
Lastly, I would check that your sd card isn't full before calling Pentax to refer you to a repair shop.
Thank you.
Pentax Espio 60S "E2" error
Hi for anyone reading this! My 60s was just flashing with this but I fixed it. Took the batteries out, swapped them and that didn't work. Tried to put the old ones back in a few minutes later and then it was fine! Just fiddle around with it. Hope this helps.
I need a driver update for my pentax optio rx18. can download one from your website
Hello, Susan -
Fixya.com does not have updated drivers for any computerized equipment. If you have not already done so, I suggest you contact Pentax directly regarding an updated driver for your Optio RX18.Pentax is owned by Richoh.You may be able to find assistance from another Optio RX18 owner through the
PentaxForums.com :https://www.pentaxforums.com/forums/7-pentax-compact-cameras/194995-pentax-optio-rx18-rz18.htmlYou will need to register (free) to post a question on a forums.Best wishes.
