20 Most Recent Pentax OptioWPi Digital Camera Questions & Answers
It is 12 years old - replacement will be far more cost-effective than service or repair.
Pentax OptioWPi... | Answered on Aug 22, 2017
That's the point of protecting pictures. You can remove the protection by reversing the procedure. Full details are in the "Protecting images and Sound Files from Deletion (Protect)" section of the manual (page 120 in my copy). If you need a manual, you can download one at
http://www.pentaximaging.com/files/manual/OptioWPi%20Manual_web.pdf
Pentax OptioWPi... | Answered on Jun 20, 2011
Could be a lens problem. Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Pentax OptioWPi... | Answered on Apr 01, 2010
Hi All,
To clarify, I wasn't looking for a solution--I was sharing the "solution" I received from Pentax directly. It seems that many Fixya users have the same prob.
Thanks,
Laura
Pentax OptioWPi... | Answered on Feb 03, 2009
Go to the link below then select Cameras on the first drop down box and then Compact on the second then click Go. then on the list to the right look for your unit.
http://www.pentaximaging.com/support/manuals-and-literature/
Pentax OptioWPi... | Answered on Nov 26, 2008
http://www.ricoh-imaging.co.jp/english/support/man-pdf/optio-e30.pdf
Instruction manual
Does the SD card have enough room / is it fast enough for video?
(the E30 records Standard def video so it should be OK)
Do you get any error messages at all?
Does it allow you to record video and then fail, or can you not activate recording in the first place?
Pentax Cameras | Answered on Nov 05, 2019
Hi, Penny,
I'm sure you will get a great deal of pleasure out of your new acquisition. To get a manual, try using Google 'Pentax SV camera manual'. You can get a great deal of help, advice and assistance from PentaxForums.com as well.
Pentax Cameras | Answered on Oct 04, 2019
To what camera does this statement (it is not a query) apply ?
Pentax Cameras | Answered on Sep 28, 2019
Hello, Susan -
Fixya.com does not have updated drivers for any computerized equipment.
If you have not already done so, I suggest you contact Pentax directly regarding an updated driver for your Optio RX18.
Pentax is owned by Richoh.
You may be able to find assistance from another Optio RX18 owner through the PentaxForums.com :
https://www.pentaxforums.com/forums/7-pentax-compact-cameras/194995-pentax-optio-rx18-rz18.html
You will need to register (free) to post a question on a forums.
Best wishes.
Pentax Cameras | Answered on Sep 04, 2019
First of all, I assume you are using an SD card (Max 2GB) as that appears to be the maximum the camera can use. That being so, all you need to do is either transfer the contents of the internal memory to the SD card, or to your computer, thus freeing the internal memory. Then set the camera up so that it writes straight to the SD card.
Pentax Cameras | Answered on Aug 23, 2019
Try Google, or contact Ricoh for your country.
Pentax Cameras | Answered on Jul 16, 2019
13-p2huxcneo513p1ejiveg1evd-3-0.jpg What was condition of the battery when it was last used?
If it was fully depleted you are probably going to need a new battery.
Very inexpensive, luckily.
Lithium batteries are superb, but if they are neglected or allowed to fully discharged they are best replaced.
Nice camera
Pentax Cameras | Answered on Apr 03, 2019
You can't. Camera need professional service. Google the manual, some cameras have a lock to keep the shutter open, press down and turn the the right to lock.
Pentax Cameras | Answered on Mar 18, 2019
TRY ASKING PENTAX WEBSITE OR Google IT
Pentax Cameras | Answered on Mar 13, 2019
Pentax OptioWPi Digital Camera Logo
6 questions posted
Top Pentax Cameras Experts
Ekse
Jerry Greenberg
Jerry Greenberg
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Are you a Pentax Camera Expert? Answer questions, earn points and help others
View Most Popular
Pentax Cameras
  • Pentax Cameras
Most Popular Question
camera turns bleeps three times turns
  • Cameras
