20 Most Recent Nikon COOLPIX S6 Digital Camera Questions & Answers
you have to make sure the movie format is compatible by Windows Media Player.
Just get this tool to help you.
1. load your file to Video Sharer
2. choose AVI format
3. click" convert" button.
Then you will get the right format.
Here is the tool for you: http://www.asharer.com/download-video-sharer
Nikon COOLPIX S6... | Answered on Nov 14, 2019
Your camera may be manifesting shutter not opening problem. It needs to get to a camera service/repair shop.
However, it's good you physically check whether the lens isn't blocked or covered with anything
Nikon COOLPIX S6... | Answered on Oct 12, 2017
All you have to do is lay your camera with the LCD side down, make sure its on a soft surface like a carpet or a pillow. Once you have it laying down, put a peice or two of newspaper, or any paper, on top of the camera. and then hit it a few times with something. like a brush or anything hard like that. it worked for me. :) good luck.
Nikon COOLPIX S6... | Answered on Sep 26, 2016
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Nikon COOLPIX S6... | Answered on Oct 03, 2013
need a new battery
Nikon COOLPIX S6... | Answered on Dec 06, 2011
The tapping sound is the noise of the motor slipping within as it fails to move. This can be due to a gear, spiral in the motor or a tightness in the drive which needs to be freed. It can also be due to an alignment shift if the hood was damaged or dropped.
Keep the lens hood on your palm and tap the hood cupping the camera with the battery removed. now replace the battery and tap after switching. Check for changes, if not it can be dirt within or a jamming within the drive which might need your experience to remove , isolate and reset. If there is no issue but the noise take your time to get this resolved after consensus with Nikon service-- complain if within warranty.
Nikon COOLPIX S6... | Answered on Oct 27, 2011
Remove the battery for some time, check the voltage and the TERMINALS of the battery. Now reset the battery after few minutes, if the camera works except for the timer action , it can be due to a malfunction in the processor. Finally remove the battery overnight and check once again.
Hello
Thank you for using FIXYA!!!
This is a suggestion. If you do not feel comfortable trying it, you will need to take the unit to your nearest service centre. Feel free to let me know if you need any assistance.
The problem might be that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair centre for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance. Also, please be so kind to let me know if you found this helpful.
Regards
Andrea
Nikon COOLPIX S6... | Answered on Sep 28, 2011
It indicates that the date and time need to be set. If it comes back on the next time you turn the camera on, then the clock battery needs replacing.
Nikon COOLPIX S6... | Answered on Jul 23, 2011
The lens is damaged and needs to be replaced. Sometimes with use or maybe an accidental hit to the lens can cause a malfunction to the camera resulting in that error. Also if you for example took the camera to the beach, getting something like sand in the camera can jam up the lens and prevent it from fully extending or retracting.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/mike_005777b2fc6bfc30
Nikon COOLPIX S6... | Answered on Mar 24, 2011
just hit it real hard in the front until you get tired or until it shows it worked for me
Nikon COOLPIX S6... | Answered on Mar 12, 2011
If you're using Windows Vista or 7, it's likely that drivers hadn't been updated for your camera. But the most error free way to download photos from your camera is to use an inexpensive USB card reader. Please see this link.
Nikon COOLPIX S6... | Answered on Dec 05, 2010
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include "E18 lens error", or "lens error, restart camera". Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many cameras, and NEVER use a case for this very reason.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in "no heat" setting, or sucking the gaps with a vacuum (careful with this one).
Nikon COOLPIX S6... | Answered on Oct 26, 2010
Sorry, no. The S6 is designed to store images and videos to memory, not to stream live video to another device.
Nikon COOLPIX S6... | Answered on Oct 19, 2010
Nikon COOLPIX S6 Digital Camera Logo
75 questions posted
Top Nikon Cameras Experts
Ric Donato
Ekse
pictureman4u
Are you a Nikon Camera Expert? Answer questions, earn points and help others
View Most Popular
COOLPIX Nikon
  • COOLPIX Nikon
Most Popular Question
found lost s6 its wires docking
  • Cameras
