20 Most Recent Nikon COOLPIX L3 Digital Camera Questions & Answers
2answers
Can you change storage settings for pictures and videos With. A Nikon CoolPix l3. Digital camera
Non Credo che ci sia un'opzione per scegliere la memoria dove salvare, quando si riempie la memoria interna automaticamente va a salvare nella memoria esterna... Fammi sapere ciaoIn English: I don't think there is an option to choose the memory where to save, when the internal memory is filled it automatically goes to save in the external memory ... Let me know bye
2/2/2022 4:38:04 PM • Nikon COOLPIX L3... • Answered on Feb 02, 2022
Batteries Exhausted Message on Nikon Coolpix L18
How could I resist assisting someone with the handle 'Charm City'? What I would advise is getting some good quality 2300 mAH or 2500 mAh re-chargeable batteries - although all batteries have a nominal 1.5v output, not all can provide the sustained power necessary for the camera.
8/21/2017 12:24:14 AM • Nikon COOLPIX L3... • Answered on Aug 21, 2017
15answers
How can i fix a stuck lens on a Nikon COOLPIX L11?
It worked. I just gently nudgged the extended(stuck) lens to one side by hand. (the side which had the gap.) There was a click sound and the lense housing fell back in place. Sweitched off and switched on again and the lense started working fine. thanks.
8/1/2016 7:08:22 PM • Nikon COOLPIX L3... • Answered on Aug 01, 2016
9answers
I dropped my camera and the lens got stuck
I banged mine around several times and tried to force the retractable lens in and out. Neither of these things worked. I finally thought "what the heck it's broken anyway" and used a bobby pin to try to force the outer lens cover off. After applying just slight pressure it unjambed the lens cover and it works fine now.
2/11/2015 6:46:39 AM • Nikon COOLPIX L3... • Answered on Feb 11, 2015
How can i open the battery door of nikon coolpix l3
Most camera battery compartments have "raised lines" on the cover. They usually suggest that you put your finger or thumb on that surface and push with a sliding motion to open the cover. Again, there are many different models, but the Coolpix I have seen have that kind of opening device. Hope this helps!
11/29/2014 7:44:42 PM • Nikon COOLPIX L3... • Answered on Nov 29, 2014
How do I turn flash on and off?
The multi selector is the round control on the rear of the camera with the OK button in its center. The flash mode button is the top button on the selector, it has a lightning flash icon. Press the flash mode button on the multi selector. Highlight the desired mode and press the center of the multi selector. The flash modes are: AUTO; Flash fires automatically when lighting is poor. AUTO WITH RED-EYE REDUCTION; Reduces "red eye" in portraits. OFF; Flash will not fire even when lighting is poor. FILL FLASH; Flash fires whenever picture is taken. Use to "fill-in" (illuminate) shadows and back-lit subjects. SLOW SYNC; Flash illuminates mainsubject; slow shutter speeds are used to capture background at night or under dim light The selected flash mode icon appears at the top of the monitor.
10/22/2014 7:11:54 PM • Nikon COOLPIX L3... • Answered on Oct 22, 2014
Videos won't transfer
Are you using View NX software for transferring files......or copy directly from memory card. Trying a card reader is an easy way....
10/15/2014 7:34:58 AM • Nikon COOLPIX L3... • Answered on Oct 15, 2014
Lens extending and then extracting wont stay on
Here is problem with gear. Something is broken or out of his position. Cameras with moving lenses have often this problem. Enough is little knock and thats it. Mine vas broken, when the child got up from the table, press the on button and and do not let the lens come out. I got to hear the crackly noice and thats all...After that im using cameras like Pentax W 90...
10/10/2014 11:03:30 PM • Nikon COOLPIX L3... • Answered on Oct 10, 2014
My camera said this card cannnot be used
What type and size memory card? The L3 works with SD cards, 2GB or smaller. It will not work with higher-capacity SDHC cards.
2/25/2014 7:20:31 AM • Nikon COOLPIX L3... • Answered on Feb 25, 2014
Sim card not working
2/25/2014 7:19:51 AM • Nikon COOLPIX L3... • Answered on Feb 25, 2014
2answers
Driver Installed
Diditial camera do not need 'drivers' for PC's operating with WinME/2000/XP/Vista
Windows does it all
11/15/2013 11:14:55 PM • Nikon COOLPIX L3... • Answered on Nov 15, 2013
Lens error repair
Here's a video showing troubleshooting steps for this problemAnd here's a page summarizing these steps:http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
5/11/2013 6:10:59 PM • Nikon COOLPIX L3... • Answered on May 11, 2013
2answers
Lens stuck error
ALSO, please see this link for further troubleshooting steps for this problem.
5/2/2013 2:18:56 PM • Nikon COOLPIX L3... • Answered on May 02, 2013
I dropped my Nikon Coolpix camera today, and the lens stuck out, it wouldnt budge... i looked for answers on the internet, and someone on yahoo said to push the lens down. So like the fool i am i did,
This camera needs to be sent away for repairs. Just like a motor vehicle, some repairs to your camera require a technical specialist to fix your problem.
4/3/2013 3:43:33 AM • Nikon COOLPIX L3... • Answered on Apr 03, 2013
I dropped my nikon coolpix s3300, and the lens is now stuck in the out position. What do I do? I have the limited warranty.
Sounds like the iris is stuck shut - the lens needs to be replaced.
2/13/2013 8:50:23 PM • Nikon COOLPIX L3... • Answered on Feb 13, 2013
BATTERY EXHAUSTED
Make sure you have the internal menu for the battery selection correct.
Choosing the wrong battery may cause this.
Rechargeable batteries and alkaline batteries are not the same.
This may also be a condition and problem caused by the camera itself, and may need repair.
1/10/2013 12:32:50 AM • Nikon COOLPIX L3... • Answered on Jan 10, 2013
S520 lens error
10/19/2012 1:49:08 AM • Nikon COOLPIX L3... • Answered on Oct 19, 2012
Nikon COOLPIX L3 Digital Camera Logo
365 questions posted
Top Nikon Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Nikon Camera Expert? Answer questions, earn points and help others
View Most Popular
COOLPIX Nikon
  • COOLPIX Nikon
Most Popular Question
dropped camera lens got stuck
  • Cameras
