20 Most Recent
Konica Minolta DiMAGE Z6 Digital Camera Questions & Answers
Unable to use card
Firstly, what size memory hard do you have? Is it an SDHC? Secondly, have you checked that the memory card isn't locked (there is a switch on the side of it). Has it worked with other memory cards?
I need a usb cable for my camera
A camera store or electronics store will likely have the correct cable. It's most likely a "mini usb" connector. If there's a Best Buy near you, they should have it.
Buy a new usb cord
The manual calls it the USB Cable USB-3. DONT MIX THIS UP WITH USB3 cable. I Think, but I'm not 100% sure they mean a normal USB cable with a mini connector. To be 100% sure check the wiki page and look if it is the second from the left. It is a normal USB2 mini connector, you can buy in almost every electronics shop. Some manufacturers did use other cables, but this looks just a normal mini connector.
How do I fix
Either the card is bad, or it is to big for the camera. If other devices can read it, it might not be compatable with your camera
Trouble with Camera download USB error
Hi wrt3 !!
Can you pls tell us the name and modell for your dell pc. Do you use usbport version 2 ?
Have you tried to use the camera on a different computer with another windows ?
Best regards
Joakim
