20 Most Recent
Konica Minolta bizhub 161f All-In-One Laser Printer Questions & Answers
I have message call service(M1) So how to clear?
firstly press menu then press quick setting then twoo time press left arrow then again press quick setting then press left aroow and after this press right arrow service mode will open at ur machine select "Maintenance Counter" now in this option select, 0 and press ok.
Desbloqueo del codigo 3806 en konica minolta bizhub 501
Power off the machine, ensure the sub power switch is on that is the one on the control panel, now hold down the utility/counter button and turn on main power switch, wait to see trouble reset on screen the touch get OK then power off. Wait 10 second power on. if code comes back replace the fuser unit do not reset again or the machine can catch on fire the code you are resetting is for the fuse the HOT Part, that could ruin a perfectly good day Btw, I’m available to help over the phone in case u need at
https://www.6ya.com/expert/normanj_7893313f0751935f
Code c0500
C0500 is a warm-up error on those little machines. Try holding the stop button while switching on, that should reset the code. It sometimes happen if it's kinda cold, or when the power dips. If the code comes back, you'll have to replace the fuser unit.
