20 Most Recent
LG 16X Internal DVD-ROM, E-IDE / ATAPI/ Ultra DMA 33 Mode DVD Drive Questions & Answers
I can see the movie
The audio_ts folder doesn't have any files, that is not causing the problem. Does the sound work for other things on the computer? Open the volume mixer by double-clicking the speaker icon in the system tray. Then check that the volume is not muted for the CD/DVD drive, or turned down too far.
My dvd writer was working perfectly but when i
When you formated you erased the driver you need to use your dvd writer as a dvd writer and player. If your dvd-rom came with a cd use it to reinstall the driver and program it uses. Otherwise you can search for your driver thru the manufacturer website or go to
www.driversguide.com and find it there.
The Drive is not listed in the device manager. The
Hello there
well what you will have to do is try going to the manufactures web site and see if there is any driver downloads for this device if so good. if not please go to
www.radarsync.com and use this totally free utility it will download on to your desktop. than it will scan the whole system and check for any outdated drivers and update them for FREE it will even get you the drivers that you are not able to get. so please try this if all else fails it has done wonders for me and my buisness
best regards mike
What normally burns out the LG Hi-Fi Amplifier?
Full 'make model (what it is)' in all questions please, first 3 words.
Capacitors can split or bulge, resistors can burn,, the transformer can fail internally..
Take it for repair unless you have the thousands of dollars of test equipment and have do the 2 year electronic course.
What does 9 red flashes mean on LG multi V LMU540HV
A communication error has occurred between the outdoor and indoor units. Faulty wiring or a malfunctioning control unit may be responsible. Contact LG customer service for assistance. Their number is 1 800 243 0000.
How to sync TCL ROKU TV to LG sound bar
You will need to connect a single HDMI cable from your sound bar to the HDMI ARC or the HDMI eARC port on the Roku T.Make sure that both of the devices are both turned on.When your TV detects the sound bar,it will then automatically initiate the setting up process. Lastly follow the easy on screen instructions to finish setting up the connection.
LG 55UM7300PUA not powering on
If your LG 55UM7300PUA is not powering on, there are a few things you can try to troubleshoot the issue. 1. Check the power cord and make sure it is securely connected to the TV and to the wall outlet. 2. Check the wall outlet to make sure it is working properly. Try plugging in a different device to the outlet to make sure it is providing power. 3. Check the power button
