20 Most Recent
LG 52SX4D 52" HDTV Questions & Answers
Mitsubishi WD 73827 Will not turn on
Does the LED blink a two digit code. This set has 2 1000uf @16V capacitors on the PWB that will cause this symptom . Let me know if you need further assistance, there are also 4 1000uf @ 35V on the DM and 3 1000uf@16v on the FMT that will cause all kinds of problems if you change the PWB capacitors I would change the ones on the other boards
No picture-lg ru-52sz51d
Depending on what light is flashing it could be a few things. If the Lamp light (the middle one) is flashing that is problem with or around the lamp. That orange or amber light is an indication that the lamp is reaching the end of its life
If it is the Temperature light (the far right one) then the TV is shutting down because it is over heating and you need to check the cooling fan.
LG DLP 52SX4D/Will not power up
Ours did the same, it was the colour wheel in the tv, it was stuck [from dust and smoke] and the tv wouldn't go past that problem.
Lg 52sx4d problem
If the red light scrolls through, you need to replace the bulb. I replaced the my own bulb, and when I tried to turn on the tv the light kept scrolling. What was wrong? I DIDNT FULLY REASSEMBLE THE TV AFTER REPLACING THE BULB.
Make sure that all the screws are put back in and it will probably work if you have replaced the bulb.
High Frequency Noise
Most sets if this: it is a transformer on the power board--we usually open and listen to locate this--on occasion we use a microphone and a scope for this.Cure is either replace the entire board or in some cases if locate to one part use hot glue to mute the noise.It is being caused by a transformer that is vibrating hard enough to make the sound-part is not bad in usual sense of the word but is not pleasing to hear.SD TECH
TV clicks but won't come on .
Check for bad capacitors in the power supply section. Sites like www.TvRepairKits.com have power supply repair kits if needed,
I have a LG 52SX4D
Hi, does it have a component video connection for the green, blue and red cable?
I replaced the lamp for
did you get a Philips lamp check that also make sure all the doors are close also you could trouble shoot more with discount merchant
